perfecto951's Avatar
Send a message via AIM to perfecto951
clutch died?
i knew it was coming. but it came on my way back from school. sucks ass. i guess it's the clutch at least. i don't smell clutch, the engine revs up but it doesn't pull nearly as hard as it should (mainly in 1's and 2nd gears.) I guess if i drive it more the clutch becomes more worn, then begins that terrible smell? Right now it's still pretty drivable - it just acts like the car is loaded down with weight. Sound familiar to anyone?
i'm just asking because i want to make sure it's not my transaxle. the tranny does make a clunking noise every time it's thrown into gear - but it's always done that. there aren't any grinding noises or anything.
input please!
1986 951, India Red. (Mine) - Not For Sale Anymore
1987 944, Alpine White. (Bother's)
2000 Audi A6 2.7 Biturbo Melange (Mom's)
Old 09-28-2003, 06:31 PM
AFJuvat's Avatar
Clutch is dying
time to replace - looks like yours is wearing out rather than the rubber disk destroying itself
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-29-2003, 03:58 AM
unluckylow's Avatar
Yeah sounds just like my 968 only Im smelling clutch and its slips every now and then out of gear I called around and it will be between $1400 to $2200 to have someone do it for me Ive been looking for a book so I can do it my self no luck.
94' 968 hardest car to find information on.
Old 10-01-2003, 10:24 AM
SoCal Driver's Avatar
Don't know why a clutch job on a 968 should cost so much. The 968 has a two piece drive shaft and a large access hole in the bottom of the bell housing. Don't have to drop the trans or pull the torq tube back.
Could this be the cost of the special clutch?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-01-2003, 11:09 AM
Depends if you need a flywheel or not. Driving any Porsche that has a dual-mass flywheel with a slipping clutch is not a good idea. If the face of the flywheel is heat damaged you will need a new one. That's where the $2400 quote came from. The $1400 is without the new flywheel.
All prices depend on the local labor rate and what parts are included in the estimate, so unless like to like is compared the price means nothing.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-01-2003, 11:14 AM
