Send a message via AIM to wawaloon Send a message via Yahoo to wawaloon
Antenna
Hey Everyone, Is there a tool that is used for removing antennae from these cars? I can't put my cover on the car properly with it on.
Thanks In Advance.
Michael R. Ganshirt
Silver 1987 924S
1995 VW Passat GLX Wagon
1986 Audi 4000S
Ausgabe Geld auf meinem porsche ist gesuender als das Spielen und Drogegebrauch.
Old 09-27-2003, 12:39 PM
Nope, the antenna is probably a non-retracting one. You would have to install a manual or power antenna so the cover would fit.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-27-2003, 12:48 PM
Hmmm..., yes, that is abetter long-term solution. Thanks, Michael.
Michael R. Ganshirt
Silver 1987 924S
1986 Audi 4000S
Old 09-27-2003, 01:00 PM
vott does ziss do?
ronin's Avatar
the mast doesn't simply unscew from the base? (mine has the leads in the windshield so I'm not familiar with standard porsche aerials)
Old 09-27-2003, 03:48 PM
bearone2's Avatar
most car covers come with a stick on patch for cutting/covering the antenna hole you cut into the fabric.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 09-27-2003, 04:25 PM
repoman's Avatar
on mine mast threads out and I stuck a plastic body plug into hole
anybody have the threaded mast section? Mine is gone and would sure save some work if I could just procure the mast.
thanks
'84 944 auto stock
Old 09-30-2003, 10:43 AM
If you have an 83-84 or early 85 with the power antenna, replacing the antenna takes about 2 hours. Performed this task last weekend on my 83. While in their, rewired the entire radio to speaker setup with new wires.
Radio now works fine and the antenna goes up when required then retracks so that my cover will fit. I'll have to fix the hole in my cover now that I have the proper antenna.
We reused the orignal wires and installed new connectors between the old wires and the new wires. Used the new antenna cable than came with the antenna kit and rerouted the antenna wire from the antenna to the radio.
Old 09-30-2003, 01:55 PM
