Help with Compression test results
I just finished testing. Tell me what you think of these findings. 86' na
1st cyl - 145 2nd cyl - 145 3rd cyl - 170 4th cyl - 200 The first and second cyl. took about 6 strokes to build up each, where as 3rd and 4th only took about 4 strokes each. I thought that I had blown a head gasket, because of coolant in th oil and rough running. I'm not sure now. Thanks for the help. |
How're your valve timing & timing belt?
Are those readings "wet" or "dry"? When running, what vacuum readings show? |
Im not sure, but I think they are all supposed to be within 10 lbs or so of each other....I know theres a percentage spec for this...the 200 sounds really weird (too high). THe 145 seems a little low (not too bad tho) -- I think 170 is OK. I know you want consistant numbers thru-out....if you readings are accurate - i think somethings amiss...Good Luck
The spec for an na (early) is 145, I don't know what it is for an 86 (late) 944 ...
The 200 and 170 sound too high to me!!! |
Repeat the test, using the same number of strokes per cylinder. Write down the results, repeat. If the second results are pretty close to the first time, then I would say they are more reliable. 200 sounds way too high but 170 is close to 180 which is the low side of the +-10% range from 200. From what you have now, I would about say you do have a blown head gasket across 1 & 2. A head gasket can be blown across the compression side as well as the oil/coolant passages. Good luck.
Dave951M |
I'm gonna try again. There is a loud metal on metal clapping sound. I think that it is a valve problem. Everything was running ok engine wise and then i put fuel injector cleaner into the tank with a fill up. Since then, I have had nothing but problems. Another thing I thought was interesting was that when I took out 3 and 4 sparkplugs, there was oil on the metal band behind the threads. I'll let you all know how the next test comes out.
If it is a loud metal claping noise it could be a rod bearing, hope not for your sake.
Whoa...
while the plugs are out examine the valve time/align marks and TDC. Metal-on-metal sounds could be piston to valve. |
Is that anywhere in the haynes. Could you give me a quick lesson on how to do that?
If it is a head gasket problem, I know it will be a lot of work. I trying to look at it as a learning opportunity because I have never taken the head of a 944. A gasket I can deal with, but more worried about having to do a valve job, or removing the engine etc... |
During the buyers inspection my mechanic came up with these numbers for my '86 NA...which he indicated were very good for a car with 120K on the clock.
#1 170 #2 165 #3 168 #4 170 ------------------ 1986 944 NA |
Aceman...yes, Haynes describes the valve
timing/belt alignment check; so does Chilton Import book. I prefer the Haynes, usually. Be sure alignment marks line up at (top dead center)TDC of compression stroke--rotate the engine (plugs out)so they do. Be sure cam belt tension is good; might as well examine balance shaft belt while you're at it. Are you confident your pressure gauge is good, by the way? |
| All times are GMT -8. The time now is 11:52 PM. |
