pschaars951's Avatar
Send a message via AIM to pschaars951
Post front fender glued down?
ok i took off the inside wheel cover and looked at the fender. It looks to have sealant all the way around where it mounts. Should I just cut through this? And does anyone know what it is so I can re-apply it when I get finished?
by the way: I am repairing my front fender because some dumb person hit me when I was parked in front a a friends house and didnt bother leaving a note or anything. If they took off any paint I would have hunted them down and killed them.
-pete
Old 06-12-2001, 05:45 PM
88_944's Avatar
Cool
I think is some kind of cock glue. I think you should put the glue back because rust will start without it.
PORSCHE There is no Substitute!
Old 06-12-2001, 06:07 PM
Post
you mean CAULK right? cause thats what I was thinking... I need to go wash my hands if it is cock glue. Anyway, I can't seem to pull the fender off... I am going to go ahead and cut through with a razor, hopefully they have this stuff at the dealership tomorrow.
-pete
[This message has been edited by pschaars951 (edited 06-12-2001).]
Old 06-12-2001, 06:26 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by pschaars951:
Hi Pete the glue that your talking about is called seam sealer you can get a tube at any auto body/paint store about 10.00 bux this stuf works better than the caulk you could buy at home depot but be advised anything it gets on it will stick to you can use a rag soaked in acetone to clean it up, from your hands and such I would recommend putting it on B 4 you install your fender to remove the old seal use a razor and try to scrape off as much as possible and remember the bigger the glob the better the job.........Stan
Old 06-13-2001, 09:35 AM
