Send a message via AIM to SlowToady
How different are the 16v and 8v motors?
I was looking for the differences between the 8 and 16V motors in the 944, I searched the board and all I could come up with was "there a few differences" but thats it; no mention of what they are. Did adding 2 more valves per cylinder really massage 20 more HP out of this engine? I don't think so, because of what I've read on here about how hard it is to really upgrade these motors. So, what exactly DID they change?
Also, would an S motor just bolt right in to an 8V engine bay? Or could one just snag a 16V head and slap it on the 8V motor?
Come on SoCal, Britwrench and AF..I know you got the skinny on this:-P
Old 09-30-2003, 04:22 PM
SoCal Driver's Avatar
Higher compression. Better breathing. One heck of a mess if the timing belt or cam chain breaks.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-30-2003, 04:26 PM
Some1else's Avatar
Here is the best way I have ever heard it put. And sorry don’t remember where it came from!
“An in internal combustion engine is nothing more then a Hugh air pump, the more air you move though it, the more HP you get.” More values= more air…
Granted there is a little more to it, but the idea is correct!
83 944N/A Summer
88 4Runner Winter
Give me a “D” Give me a “Y” Give me a “S” “L” “E” “X” “I” “A”!!
What do you get? Dilex.. Dislax.. Dylsia… AHH F**K IT!!!!!!
Old 09-30-2003, 04:36 PM
Talk about fast responce time
By better breathing, were they any different parts, or just modifications to the 8V parts? Ported/polished manifold, etc?
Is the risk of the 16V motor a better bet than trying to squeeze 20 more HP out of the 8V? I figured some higher compression pistons, early forged rods, some head/intake work, ECU and headers/exhaust might add a few ponies. Any ideas on numbers?
Old 09-30-2003, 04:39 PM
A Hugh air pump?
Old 09-30-2003, 04:43 PM
Domed pistons, completly different head, intake and exhaust design.
Wasn't there an increase in cc's or is that the S2?
Old 09-30-2003, 04:45 PM
Thanks for the info You rock.
AFAIK, the increase in CCs came with the S2 with a displacment of 3.0L. The S2 is basically a bored and stroked S.
Old 09-30-2003, 04:51 PM
Some1else's Avatar
Originally posted by SoCal Driver
A Hugh air pump?
Err.. Opps!
perhaps "huge" would work better??
See sig
83 944N/A Summer
88 4Runner Winter
Old 09-30-2003, 05:10 PM
A huge Hugh would work better!
Old 09-30-2003, 05:12 PM
MrPants's Avatar
its like a riddle.
whats the difference between 8 and 16 valve engines?
twice as many valves to bend!
84 944 Non Alcoholic
Old 10-01-2003, 12:21 AM
repoman's Avatar
S1 has pre-tensioned belts; S2 uses spring tensioner
I bet wiring harness swap is high on difficulty scale for 8v to 16v
My guess for easiest upgrade swap is '89 2.7l 8v motor; 10-15 hp maybe?
anybody ever done a 2.5 to 2.7 swap?
'84 944 auto stock
Old 10-01-2003, 03:17 AM
