Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Question Pretty Serious Design Flaw?
I've noticed while washing my 944 that all the runoff water that comes off of the winshield pools in the front of the engine bay, where there is some drainage. Some water does, however, occasionally end up on the battery and other key components! Is there a reason for this? Were the Porsche engineers just not thinking when they designed this? Has anyone else wondered about this weird design flaw?
[This message has been edited by CJFusco (edited 06-13-2001).]
Old 06-13-2001, 12:02 PM
88_944's Avatar
Cool
I have that factory battery cover.
PORSCHE There is no Substitute!
Old 06-13-2001, 12:27 PM
Banned
Post
get or make a cover for the battery... If you are having water collection problems, make sure your drain holes are clean. To clean them out, use a piece of small but stiff wire to snake them.
Old 06-13-2001, 12:37 PM
Obin Robinson's Avatar
Cool
Originally posted by mideastmafia:
i noticed this too. my battery terminal gets all rusted and if you think about it, electricity runs thru water. that means that it can toutch + to - .. not good, what should we do?
SHAUN
relocate the battery. i am doing this in my 924.
obin
Old 06-13-2001, 12:38 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by CJFusco:
Hi All, I have a very simple but very effective solution to the battery gets wet problem I have used it on all 3 of my 944`s
Get a coolant bottle and cut out one side and remove about 2inches off the top then place this over your battery cut slots for the wires but dont remove the plastic let the sides rest on top of the wires now when it rains or you wash the car only the sides of the battery will get wet, also put some grease on the battery posts, this will prevent corrosion of the terminals.........The big deal about the battery is that it makes acid vapor, and this vapor will get deposits on the battery that will wash off when it rains or the car is washed this then falls into the battery box resulting in holes from acid corrosion, so if the top of the battery is covered then there will be no acid runoff into your battery box.....now would also be the time to inspect your battery box for corrosion and fix it with some fiberglass bondo after repairs are made I suggest using some rubberized undercoating , let this dry thoroughly B4 replacing the batttery
Old 06-13-2001, 12:56 PM
Post
Where did you get a factory battery cover?
Old 06-13-2001, 01:08 PM
Post
Actually Shaun, water is an insulator. Water only conducts when ions are dissolved in it. Also, 12volts isn't exactly much of a potential, so very little current will actually flow through the water(unless you start pouring a bunch of salt into the water).
Old 06-13-2001, 01:31 PM
Bay Area Patriot
TheStig's Avatar
Post
ya Mideast get the cover, like my Huntley Racing one
heheheh
Porsche. Es gibt keinen Ersatz.
Old 06-14-2001, 12:10 AM
