Obin Robinson's Avatar
Smile high RPM valve springs for 924?
hello,
does anyone know who sells the high RPM valve springs for the 924? i thought that webcam sold them, but their site is defunct:
http://www.webcaminc.com
thanks!
obin
Old 06-08-2001, 07:34 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Post
Obin..
That site works fine for me.. Try it again
Gordon
1981 924 N/A
Old 06-08-2001, 11:27 PM
Red face
WHOA! i tried the site again and it did work. unfortunately the prices are so high that i had to do a double-take to make sure they weren't stating the prices in Yen, or Pesos, or just liked to move the decimal place over to the right.
in any case, they don't have the springs for the 924
obin
Old 06-09-2001, 03:53 AM
Post
obin,
If you have one out, and spec book for installed height, check Summit Racing for a close matchup on Crane Springs.
Part No CRN-99848-16 $ 66.95 for 16 springs.
Without digging up an old spring & the spec book, this one seems close, 105lb at 1.700, 296 at 1.200, binds at 1.153, 1.255OD .870 ID.
drew1
edit: If I remember right, 924 is dual spring while above no is a single.
[This message has been edited by drew1 (edited 06-09-2001).]
Old 06-09-2001, 02:20 PM
Thumbs up
thanks so much drew1!!!!
THOSE are prices i like . problem is now that i can't get the F**KING springs OUT!!!! the ones in there are STUBBORN. they simply don't want to budge... i wonder if i already have high rpm ones in there and was never told by the Previous Owner. is there any way to get them tested? i can't start the port and polish until they come out though. i got a valve spring compressor from sears but it won't work... or am i doing something wrong?
thanks again!
obin
Old 06-09-2001, 02:27 PM
Post
One thing you might to loosen the keepers is to set the head up on wood blocks where the valves won't hit a hard surface surface, spray the valve stem/retainer/keeper assy with penetrating oil, put a socket on the end of an extension on the retainer and knock the devil out of it.
The stock springs are pretty tight, new ones from Porsche are about $6 or $9, if I remember right. If you could get something down in there to cut the old ones, it would be good, but is it possible?
The big 9 or 10 inch C clamp works better than the crafstman Valve spring compressor tool, in my opion.
drew1
Old 06-10-2001, 01:55 AM
Dave951M's Avatar
Post
We used the c clamp route with a socket tack welded to it. The socket was a junker that was cut out quite a bit to gain access to the keepers. Cheap and effective.
Dave951M
Old 06-10-2001, 07:14 AM
Angry
ok,
these 924 valves are pissing me off EXTREMELY. i have a feeling that if i crank down any harder on them... i'll end up either bending the valve or busting the cylinder head.
i am using a 8" c-clamp and i put a u-shaped piece of metal on the end of it. i clamped down as HARD as i could... and the piece of metal bent
i don't want to break anything, but i want to know HOW hard do you have to crank down on these springs before you can get them to deflect enough to get at the little spring keeper?
anyone want to let me "rent" a valve spring compressor (even a home made one). i have looked EVERYWHERE in town and NOBODY has one for Porsche 924 (or for Audi or VW SOHC either).
thanks!
obin
Old 06-10-2001, 03:27 PM
Send a message via ICQ to Audi_VW_Porsche
Post
Man that sux... Anyways I know that www.audiquattroparts.com rents tools out... They have parts for Audi's so they should work just fine... Ohh and tell us how the Port & Polish turns out ok?
Old 06-10-2001, 11:28 PM
Post
obin,
wanted to do some checking before I told you to try heat on the retainer to help break taper loose from the keepers. reason is it might take temper out of springs, keepers, valve stem tip, & retainer.
took one of the 924t springs(same part # as 924na) that i removed & took diminsions of inner & outer springs. using machinist's handbook calculated load at room temp at1.700 (41 lb) & 1.200 (136 lb). this is less than half of of crane springs posted above. retainers can be bought to fit these springs. manley & others can fab big stainless valves that locks can be bought to work with retainers.
big concern is wear on cam & lifters (about $50 each) with heavy springs.
saw that you live in Ithaca, NY. going up that interstate that comes through PA, then Binghamton , you turn off to the west to get to Ithaca. Seems like I saw something about a race track on that road where they run 4 cyl. the ford 2300 that"s popular use rocker arms but some of the round trackers may be able to provide info on parts sources & machine shops.
drew1
Old 06-13-2001, 09:42 AM
paulhagedorn's Avatar
Send a message via ICQ to paulhagedorn
Post
Obin,
Have you gone to AutoZone? They rent spring compressors for $20 and give you your money back when you return the tool. It is a pretty nice system, but don't know if they have the right tool for a 924. Worth a shot!
Paul
Old 06-13-2001, 11:46 AM
Post
Originally posted by paulhagedorn:
Obin,
Paul
DAMN!!!! if i knew this about a week ago . in any case, i DID get the exhaust valves out. i am going to sell the compressor i bought too. anyone in need of a Spring Compressor for GM engines? never used (though one attempt was made) and still in package. i lost the receipt though.
obin
Old 06-13-2001, 11:50 AM
Post
Glad you got the exhaust out. Saw in earlier post about you wanting even homemade compressor. Advise if you want to borrow part that I use with compressor & C clamp.
drew1
Old 06-14-2001, 07:54 AM
