Power steering belt?
There is a belt that is connected to the power steering pump and then to something else. This thing is slipping like mad, and every time i turn the wheel i hear it slipping around. What is this, and how do i deal with this problem? Should i tighten it, and if so how do i tighten it?
Remeber im new to this whole porsche thing, oh yeah i fixed the horn. It beeps really loud now.
86' Porsche 944 N/a
Old 10-01-2003, 02:09 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
there is a small rod connecting to the bottom of the pump. this is the rod that you use to tighten the belt. it called an adjusting strut. if you tighten it it should stop squeeling. (whahoo! i can answer a question!)
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-01-2003, 02:33 PM
woohoo! thanks lol
86' Porsche 944 N/a
Old 10-01-2003, 03:05 PM
SoCal Driver's Avatar
Just a bit more detail:
There are locking nuts on the adjusting screws. These are right and left threads. Clean off the exposed threads with carb or brake cleaner and you will see which way to turn the nuts and strut body.
You have to loosen the bolts at each end of the strut before you change it's length-tension. Tighten them after you adjust the strut and lock the jam nuts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-01-2003, 03:08 PM
If you go this far, you should probably consider replacing the belt with a new one. This will give you the best insurance against problems for some time to come.
Old 10-02-2003, 10:15 PM
