Brandon85-944's Avatar
Send a message via ICQ to Brandon85-944 Send a message via AIM to Brandon85-944
Post Differences between a 1985 and 1 1985.5 944n/a.
Hey all... My friend was gawking at my car one day and he asked me what year it was and relplied that it was an EARLY 85...then he asked why did the make two 85's....then I acted dumbfounded and tried to change the subject....so I'm now asking you all...why did they make two and what are their differences..?
thx.
Brandon85-944
Old 06-11-2001, 05:55 PM
paulhagedorn's Avatar
Send a message via ICQ to paulhagedorn
Post
Updated interior is the main difference, but I think they also reworked the computer and it is possible to put in an aftermarket chip in the late 85. This might have also been when they switched to using the Phone Dial wheels as standard.
Paul
Old 06-11-2001, 06:09 PM
Post
WHY they did it is because they were planning a model change, and it didn't match up with a model year change-over. Therefore, some of the '85 model year got the old style, and some of the '85 model year got the new style.
this mid-model year changeover is more common than you think. Other car manufacturers do it too, just nobody advertises it.
Mike
Just as a side note -
I've heard quite a few rumors about people with cars very close to the change-over VIN, where some early cars had a few late parts, and some late cars had a few early parts. Mostly minor parts though. They simply used up the early parts they had left over, and when they were short, they used some late parts on early cars.
Old 06-11-2001, 07:16 PM
Post
The only other difference other than the interior/dash is the newer models use aluminum suspension components. Although this change doesn't correspond exactly to the model year (some older models had this treatment) it is generally thought of as a midyear upgrade...
Corey
'90 944 S2 Cabriolet
Old 06-12-2001, 04:41 AM
RaF944's Avatar
Post
And the antenna is no longer outside but in the windshield.
85.5 Porsche 944
Old 06-12-2001, 01:19 PM
Banned
Post
and the stearing wheel position was raised a bit for more leg room.
door handles have embossed "PORSCHE" lettering.
some cars got a three wire O2 sensor (CA SMOG)
Old 06-12-2001, 02:00 PM
Banned
Post
Shaun... now that I think about it, you may be both right and a bit wrong.. my 86 has the script on the door handles but our 85.5 did not. I guess that the door handles were one of those parts that when used up, moved over to the updated part. FYI, my 86 has a late 85 build date...
Old 06-12-2001, 02:43 PM
RaF944's Avatar
Post
my 85.5 has the porsche lettering on the dorr handles...well one of them...cause the other one was replaced.
85.5 Porsche 944
Old 06-12-2001, 03:36 PM
Post
hey thanks guys...by the way...how do you go about checking the history of your car using the VIN number...is their an internet site or do you have to use the tele....?
Brandon85-944
Old 06-12-2001, 06:36 PM
Post
Many differences between 85 and 85.5 - check out the Porsche Parts and Tech Ref Manual.
Old 06-14-2001, 01:36 PM
