CrazySOB's Avatar
Send a message via AIM to CrazySOB
Post What Transmission, Help
My car is a 1984 944, I need a five speed transmission, but I don't know what years would fit mine. Can anyone tell me Please?
Old 06-13-2001, 03:10 PM
CrazySOB's Avatar
Post
Will a tranny for a 83 944 fit?
Old 06-13-2001, 03:22 PM
Blackfoot's Avatar
Post
same tranny up through '87 (except for turbo):
http://www.connactivity.com/~kgross/944faq02.html
if you want to go like 180 mph, put in a 951 tranny. :-)
Old 06-13-2001, 03:31 PM
CrazySOB's Avatar
Post
Would a 951 tranny bolt right on with no mods.?
Thanks BlackFoot, 83-87 all the same, That's all I needed to know.
Old 06-13-2001, 03:35 PM
Rollins's Avatar
Send a message via ICQ to Rollins Send a message via AIM to Rollins
Post
WHOA WHOA WHOA!! Blackfoot, you forgot to mention that to hit 180 you also need yellow wires and a huntley sticker. Come on man!
Old 06-13-2001, 04:05 PM
Post
you need an auto tranny to hit those blazin speeds, just ask shaun
Old 06-13-2001, 04:47 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by CrazySOB:
Hi Crazy well the trans es will all bolt up BUT there are some differences, one is the speedo drive I think from 85.5 N later it has a electrical drive so now it depends on what year you have up to 85.5 there is a cable from the LF wheel to drive the speedo
so if you dont need a speedo drive from the trans then you have more options also the final drive in from a turbo trans is different so this will change your gearing..also a 86 and newer trans from 951 will have an oil cooler attached altho it was an option from 87 on on the 951..
I would look for a lo milage unit that is made for your year, try to find out if the carrier bearings have been replaced and all the seals and all the syncros, if your getting a rebuilt unit.....Stan
Old 06-13-2001, 05:10 PM
951carter's Avatar
Post
you do NOT want a 951 transmission. it would make your car a dog. try calling oklahoma foreign, we have used them many times very succesfully for engines and transmissions. where are you located? if near Virginia we can fix yours for you or do the swap.
Old 06-13-2001, 05:46 PM
CrazySOB's Avatar
Post
I can't afford a rebuilt one at this time, I have to go with a used one. Anyone have one for sale?
Thanks, Steve
Old 06-13-2001, 05:54 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
I (as always) would be insterested in a transaxle with lsd.
Say Carter, if I brought you my transaxle, how much could you rebuild it for? How'bout turnaround time. Currently I don't have an lsd transaxle, how much would it cost to put one in there, while rebuilding?
Ahmet
It's all the driver...
My page over1g@hotmail.com
Porsche owners Gallery.../My 944
Old 06-13-2001, 09:34 PM
Blackfoot's Avatar
Post
i burned out today and left tire marks on both sides. that mean i have lsd?
Old 06-13-2001, 09:59 PM
1.2gees's Avatar
Thumbs up
Haha, pretty much though it's not a 100% way to tell.
(Jack up the rear end, in gear spin one of the wheels one way, if the other spins the same direction, you have lsd, if it spins the other way, you have an open diff.)
Ahmet
Old 06-13-2001, 10:22 PM
Bay Area Patriot
TheStig's Avatar
Post
word of warning....if u use a 944 Turbo tranny u'll lose a lil acceleration. But gain alot of high end. I did it....3rd tops at 105
Porsche. Es gibt keinen Ersatz.
Old 06-13-2001, 11:39 PM
CrazySOB's Avatar
Post
Well I found one an 83. That should fit my 84 from mcabbott off the Pelican classifieds.
now I just have to get it here and put it in.
Thanks for everyone's help, (I'm sure I be needing it again) Steve
Old 06-14-2001, 11:59 AM
CrazySOB's Avatar
Post
Here's a LSD, if anyone's interested.http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=592423318&r=0&t=0
Old 06-14-2001, 12:12 PM
