Wardog's Avatar
removing power steering pump on a 1986 944 NA
Does it afects that much the handling??..................how do I do it?? I only have to seal the houses dont I???........
Step on it!!!!
Old 10-02-2003, 08:33 AM
AFJuvat's Avatar
Sealing off a power steering rack is not recommended - you will burn up the steering rack.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-03-2003, 04:21 AM
SoCal Driver's Avatar
Thought you could pack it with grease?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-03-2003, 05:49 AM
Let's go shooting.
Dark Skies's Avatar
You'l need to stick in a replacement manual rack if you remove the pump. You may need to stick on slimmer tyres too - possibly 195's as 205 / 215s might feel a little heavy to turn after a while. If you do then you'll notice less grip.
Why do you want to do this?
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 10-03-2003, 05:52 AM
To keep the rack in good condition for short periods of time without the power assist all you do is remove the belt from the pump. Keep everything full of fluid just with out the belt. Dont run it that way for more than a few months tops.
Travis
Rennbay, inc. 888-739-7839 x944
Old 10-03-2003, 06:45 PM
