Updating 944 S2 Cab
I quickly got a glance at the interior of a 968 and noticed it is almost identical to my 90' 944 S2 Cab.
I was wondering if it was possible to update my 944 with options like (1)one touch or auto-down window switches, (2) cruise control with decelerate, (3) keyless entry? Did Porsche incorporate these options on newer 944's or 968 I also do not like reaching under my dash every time I want to turn my radar detector on or off or to adjust the volume. Sooo... I'm also looking for a 3 position rocker switch for my K40 radar detector that will fit in one of my empty plug spots on my dash. The 3 positions would include center for off, top for highway mode, and bottom for city mode( the actual icons on the buttons do not matter as long as they look consistent with the rest of the interior). I'm also thinking of buying and modifying a gauge dimmer or intermediate windshield wiper adjuster for a volume knob for the radar detector and put it next to the 3 position rocker. As a side note I do not want to use any switches or buttons that do not look stock otherwise I would have just stuck the original switch that comes with the K40 right on the dash. Any suggestions or help would be great. |
back to the top of the list
again, back to the top
For Keyless entry you need power locks. If your car doesn't have them then you can get the motors installed along with the system. Best Buy has a good system made by Ungo (believe that's their name. Best Buy also installs the lock motors. For the switches you can try buying used switches that for a 944 and using them. A used fader switch could prolly work for the volume. Try checking ebay, or looking in catalogs to get new ones.
-Tim |
I found an excellent solution to one touch power windows. It's an kit that works for all power windows.
http://www.autoloc.com/detail.lasso?itemid=WC1000 I'll report back after install. |
| All times are GMT -8. The time now is 03:14 PM. |
