				Tranny oil.....clarifications
			Ok.....leg work done, now I want to do it.....
				I want to do it this weekend, so I will go buy the Mobil 1 tranny fluid. Now, I've never bought tranny fluid for a manual car. I mean, I use ATF in my dirtbike gearboxes and like the results, but in a manual tranny I need to know exactly which tranny fluid I amlooking for at the local parts store (Auto Zone, O'reilly's, Advanced Auto parts, etc...)? My mechanic has a pump that I can use, but I want to get the correct oil, of course, and will go with Mobil 1 AND the correct amount. Thanks...
	83 944 N/A 5 sp. (mine) 90 Acura Integra auto (sons) 2000 Honda Odyssey EX auto (wife) 83 Suzuki LT 125 (4 wheeler) (wife) 92 Honda XR 80 (son) 97 Honda CR 125R (son) 98 Honda CR250R (MINE) 2000 Kawasaki KX 65 (son) 2003 Honda XR 50 (Son and daughter)  |
			The quart bottles of trans lube can be use to fill the trans. The top plug opening large enough for the neck of the bottles. A little twisting of the rectangular bottle as you pour is necessary.
	Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix!  |
			Thanks......
			So, I pour in about 3 qts until it begins to overflow or what? What IS full capacity? I can call the local dealer, but they've messed me up more than I care to mention. And, lastly, what is the Mobil 1 tranny fluid called? "Manual tranny fluid 80/85w"???
			I would get a good synthetic. Quiets those abused gears down!
			This stuff is good though I'm sure Mobil 1 is OK :
			http://www.redlineoil.com/redlineoil/gearolti.htm#75W90NS Paragon parts sell it. Don't use a higher grade than 75W90 or your shifts will suffer (thick oil = doesn't run off synchro cones as easily) Mark
	1991 944 S2 (no more, sold it, gone to a good home) 2003 Infiniti G35 Coupe, 280hp, Black  |
			I use Swepco it took a little over 3 quarts. You just fill it untill it starts to come out of the upper hole.  If you cant fit the bottle in there you any autoparts store sells a cheap plastic pump that screws on to the top of the quart bottles.  They are only a couple of bucks.  I had to use one on the Intrepid.
	Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs.  |
			Dave,
			beaware, DO NOT FILL SO IT COMES OUT. UK is 2 (ish) ltrs, check in your manual what the US equivalent is. The best way I found is as below 1> remove the filler plug first 2> remove the drian plug SECOND 3> drian the oil, if necessary, leave for a while 4> refit the drain plug (and correctly torque) 5> now for the UK car it was 2 bottles exactly, I poured the oil into one of thoes one man brake bleeder bottles, and when connected up the oil came outta the hose easily. 6> if it is 2 litres eg. use just that, the level MUST be about 6mm (?) from the bottom of the filler hole, UNLIKE other cars dont just pour it in till it overflows, overfilling can cause an excess of preassure, and loss of oil trhough seals, usually, at the other end of the transaxel, where the brake disks are (rotors), too much preasuure is bad for the box, overfilling causes drag and in theory higher MPG do what Dr.Porsche recommends not
	----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com  |
			 Custom User Title
			Uh-Oh---
	Is he right about overfilling?!? Should I drain some out? I just kept pumping it in till out it came. Please advise!  |
			rammstein,
			check your drivers manual or ask a dealer, I think even the Haynes says it (soory not at home so I cant scan it) specifically says 6mm (or there abouts) BELOW the filler hole
			http://www.tech-session.com/kb/index.php?page=index_v2&id=54&c=4
			from the Paragon site DO NOT OVERFILL
			I just picked up 3 qts of Mobil 1 75W90 at auto zone for $7/qt.  I also asked them to look up capacity and it says 2 and 3/4 Qts.
			My next question.....I want to do this real soon, so could I do this in my driveway? Will I have problems filling it up w/out a pump? But if auto zone has one for a few bucks, then I can pick one up. I understand it takes a 17MM hex, so I will secure that for sure. What is the status on filling ti it overfills OR putting in 2 and 3/4 qts? See why I ask so many 'stupid' questions? I'll plead ignorant anyday if it saves me money in costly repairs because of pride!! See.....as you get older...who cares???
 If that is the capacity for a US spec car then cool. driveway no problem. possibile, its at an awkward angle, the best is with a brake bleered kit as I said. DONT OVERFILL, trust me, DO NOT OVERFILL and again for the people at the back DONT OVERFILL. see the link in my previous reply, has full procedure and PICTURES, paragon I think is a US site
			Adrian, I just printed the paragon page you referred to and it makes me feel ALOT better.  It does not look that difficult, either.
			My next question was going to be: "Where are these two hex filler/drain bolts?", but you took care of that. 2.75 qts is what Auto Zone's computer says.......I am going to call the dealer and ask them just to be safe, because paragon lists it On behalf of myself and others, thank you very much......
			no promlemo,
			the next reply I'm expecting is "The cheque is in the post" ![]() laters Ade
			Sorry about the bad info.  I should have checked the procedure before I posted.
			Thanks for the correction adrian jaye.
			OK I dont know much but I can read and the FWSM says at least 6-8 mm below the fill plug 2liters Appox.  So happy filling!!!
	83 944 with 87 engine 5-speed LSD burnned  |
			I recall someone posting that you should always be sure to take out the FILL plug first, just to be sure you can get it out okay, before you take out the drain plug.  That way, if you strip the fill plug you can still drive the car if you need to.
			hmm, about 2 weeks ago, i decided to check the fluid level, and i had a real time, getting the plugs loose!  i would check the filler plug first, then the drain, for the reasons listed above.
					i used a 17mm hex allen wrench, and ended up applying an 18" pipe to the dang thing too, AND, i also had a wrench at 180, to the pipe, pulling on the pipe, and pushing with the wrench. this helps the 17mm wrench, from coming out, as you "give it some". trust me, your knuckles will thank you! good luck! bob.
	1984 944 na. FR. WILK power prom/dual chip. 2005 buick. daily beater 2002 grand am--better halfs ride. olds 98 royal brougham--gone, but not forgotten.  |
