Send a message via AIM to hootme
Electrial problems
I have a 83 944 and I am having a few problems, one is if I turn my lights on or my turn signals on my wipers come on. Also my fans for the radiator will not come on and I have checked the fuse and it is good.
Old 10-02-2003, 08:42 PM
SoCal Driver's Avatar
Electrical problems are most likely the steering column (stalk) controls. May need to clean and tighten the turnsignal and wiper arm assemblys or even replace them.
There are two fuses for the fans. Check out www.clarks-garage.com for a chart of which fuses and relays do what. Clark also has some good reading on the way the cooling system works and it's problems.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-02-2003, 11:03 PM
