dzachry's Avatar
Send a message via AIM to dzachry
My 84 944 has a miss!!!!
Here is one for yawl, under no load at an idle or driving at 2000 to 2400 rpm I have a miss. it goes away under a load or during de-acceleration. I was thinking that it might be Vacuum but I would think if it was vacuum it would happen at 4000 rpm as well as long as there was not load?????
What do yawl all think???
David Zachry
84 944
Old 10-03-2003, 10:08 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
plugs and wires would be my first guess.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 10-03-2003, 10:21 AM
Scott R's Avatar
Vacuum leak, check the J-boot on the underside for cracks.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-03-2003, 10:47 AM
dzachry's Avatar
Where is the J-Boot???
David Zachry
84 944
Old 10-03-2003, 11:59 AM
Scott R's Avatar
Between the air flow meter and the throttle body. It's attached to the engine as well as the stationary air box. So when they get older and brittle the start to crak from engine vibration.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-03-2003, 12:08 PM
dzachry's Avatar
Oh OK Duh!!!!! LOL
I just had this Boot off and it looks good any other sugestions??
David Zachry
84 944
Old 10-03-2003, 12:39 PM
Scott R's Avatar
Just to check all of your vacuum connections, and all of the "T's" for cracking and splitting. Beyond that you could have a failing injector, but thats rare on these cars.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-03-2003, 01:23 PM
SoCal Driver's Avatar
Your intake maifold may be loose or warped. Mine was and gave much the same problems. Careful as you may have a pulled stud/bolt or two.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-03-2003, 03:11 PM
dzachry's Avatar
I will check on this in the morning. it is possible that the intake is loose because I just rebuilt the top of the motor. I will check all of the vacuum lines and the intake. is there anything that anybody would recommend to use as a fuel additive to clean the injectors??
David Zachry
84 944
Old 10-03-2003, 08:26 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Techron seems to do the trick
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 10-03-2003, 08:28 PM
bearone2's Avatar
i used chevron/techroline sul years ago to clean a lot of varnish from the injectors because of a lot of sitting and the gas went bad. it took 5-6 full tanks to clean the injectors but it worked.
One can of techron/one tank may not be enough if the gas got real funky.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 10-05-2003, 05:20 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I would recomend a compression check
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-05-2003, 05:54 PM
dzachry's Avatar
How would a difference of compression make it run bad in a curitan rpm range??
David Zachry
84 944
Old 10-05-2003, 09:01 PM
todwic's Avatar
because at higher RPM's the miss could be disguised by the harmonic vibrations of a faster revolving stuff.
'86 951
Old 10-05-2003, 09:25 PM
dzachry's Avatar
OK it is fixed!!!!!!! Here is what happened. There is a set screw holding in the rotor and the shaft. The set screw for the shaft came out. This caused the rotor to travel into the top of the cap and desrtoy the cap and rotor. the miss was caused by the screw comming out and the shaft turning inside the rotor a little bit then then debris caused the spark to travel where it does not belong at that time. WHEW IS that Clear????
David Zachry
84 944
Old 10-09-2003, 12:35 PM
bearone2's Avatar
i feel better already.
Old 10-09-2003, 12:43 PM
Loose rotors and broken coil to dist wires. They get you every time!
Old 10-09-2003, 02:29 PM
bearone2's Avatar
if it's not the grounds.
Old 10-09-2003, 03:06 PM
