Question Motor Mounts / Sway Bar Bushings
I need to replace both my engine mounts and sway bar bushing but need to know about how long it will take and if I need any special tools? Can any one give me some advice on this issue. I am gonna be doing this on my 944 turbo 1986.
1986 944 Turbo
Old 10-04-2003, 02:46 PM
AFJuvat's Avatar
You will need a way to support the engine from above to remove the engine mounts. Once the engine is supported, remove the cross bar to access the mounts.
Sway bar bushings are not difficult - use a little silicone spray or soapy water to help the bushings slide into the mounts.
No special tools required for either - figure an afternoon to do the job
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-04-2003, 03:13 PM
Scott R's Avatar
You need a 3/8 angle head ratchet for the motor mount bolts, and you can jack the engine from ther underside with a floor jack and a soft wooden block.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-04-2003, 03:24 PM
Sure do appreciate the help I have done all this work on my old truck but this porsche I just ggot and It is a whole other world to work on I got to tell you sometimes I fell like I couldn't even change the oil. What is the best our easiest way to see what size bushing I need I have seen three our four diffrent sizes in the stores?
1986 944 Turbo
Old 10-04-2003, 03:31 PM
AFJuvat's Avatar
Measure the sway bar diameter in millimeters) - they came in 2 or 3 sizes depending on year\type. The outers should be the same size regardless of diameter, the inners are the ones that are different
AFJuvat
Old 10-04-2003, 03:38 PM
You won't be able to find sway bar bushings in "stores." You need to get them from either your local dealer, or through an on-line vendor like Pelican Parts, Performance Products, Zimm's, ect.
As for motor mounts, there is some heated debate as to the virtues of using original Porsche parts versus aftermarket parts, with the general concnesus being the after market parts are sub-standard.
I have not gone through a motor mount job yet, but from what I gather, the after market mounts are not as durable as the Porsche mounts, and the after market mounts require using shorter bolts than the original Porsche mounts. There are some significant threads about this topic over on RennList (http://www.rennlist.com).
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 10-05-2003, 09:35 AM
SoCal Driver's Avatar
wsburgos,
Both OEM and after market mounts use a bolt rather than the somewhat clumsy through bolt and nut the originals used. You can not use the bolt that comes out of the original bolt and nut application as it is too long.
The trick to know if you need engine mounts is to stick your hand between the top of the cross member and the bottom of the oil pan. If you can get most of your hand in there, up to the knuckles, then the mounts are good. If you can only get your finger tips in then it is engine mount time.
Did your car some with any maintenance history? Any old repair bills?
I ask because the timing and balance shaft belts are of prime concern on these cars.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-05-2003, 04:41 PM
YEAH I AM GONNA REPLACE THE TIMING BELTS AND THE BALANCE SHAFT BELTS SOON THEY ARE NOT CRACKED SO I AM GONNA WAIT A LITTLE LONGER. BUT MY MOTOR MOUNTS ARE SHOT AND SO ARE MY BUSHINGS ALSO MY STEERING RACK IS LEAKING A LITTLE BIT OF FLUID SO I AM GONNA TRY TO REPLACE THAT MYSELF ALSO.
1986 944 Turbo
Old 10-06-2003, 10:03 AM
repoman's Avatar
wsburgos,
steering rack leak will eat passenger side sway bar drop link bushing.
anyone know a good source for these bushings? my end bushings are ok
my belts looked fine at 45K but I feel SO much better after changing them.
'84 944 auto stock
Old 10-07-2003, 10:27 PM
TCMdocs944's Avatar
Yup, just did the job on the inner sway bar bushings....$10 for both at pelican parts... you need a 13mm socket and wrench..shouldn't be on that tight. If deterioration is bad, its been fluid fouled...check surrounding area for other problems and find the leak..
Very easy job about 30min to 1 hour BUT ... you really have to muscle the bushings on! (screaming and grunting required)..BTW I found it simplier to not remove the bottom pan/cover while doing this job.
I'd give this job a 1 beer rating.
wsburgos---- STOP YELLING..Hurts my eyes.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 10-09-2003, 08:36 AM
I thought there were a total of eight bushings am I mistaken?
1986 944 Turbo
Old 10-09-2003, 03:43 PM
TCMdocs944's Avatar
My na front swaybar has two inner and two outer. the outer were in great shape but the inner were shot.
check pelican for the part and they have a good diagram of the swaybar under the photo.
Old 10-09-2003, 03:47 PM
Maybe you're thinking about front control arm AND sway bar bushings.
Cliff Hipsher
'87 944 India Red
Old 10-09-2003, 03:54 PM
TCMdocs944's Avatar
If your thinking about removing the control arm and changing the bushings you will be bumping up that time/beer factor considerably.
I looked at the P manual for the control arm bushing deal and decided to wait until they REALLY need it.
Old 10-09-2003, 04:05 PM
The car is in the shop right now getting new control arms they should be replacing those bushings also right.
1986 944 Turbo
Old 10-09-2003, 04:08 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
What is a time estimate on motor mounts, i need to do those also.. and i want to know what kinda time I'm looking at on that one.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 10-09-2003, 04:22 PM
The motorr mounts I heard about 2 to 3 hours but I am sure it will take me longer.
1986 944 Turbo
Old 10-09-2003, 04:37 PM
repoman's Avatar
my control arm bushings are fair; I'm going to let them go for awhile.
only one sway bar bushing is bad; inner right under power steering leak.
I'm changing the rack in Spring
I don't have a belly pan so inspection is easy; after I restore under-carriage I'll get a pan
My passenger side motor mount is torn but clearance is ok and car is smooth.
I'll probably put the motor mount job on "someday" list
next weekend '44 goes in storage with TR8; I always take a 6 month winter break from the car hobby.
'84 944 auto stock
Old 10-10-2003, 05:18 AM
