Bleed Bolt
I bled my cooling system by loosening the bleed/bubble bolt on my radiator hose housing. After tightening, I have a slight leak around the bolt, is this common or did I overtighten? I only snugged it up. Should I place a washer in between?
Thanks!!!
Richard
_______________
'00 Mazda 626 ES (this car rocks)
Schwinn Apple Krate
College days...'69 Hurst/Olds and '71 Roadrunner
Old 10-04-2003, 05:07 PM
speed's Avatar
I would try a new plug and check the mating surface, then I would try a soft washer like copper or aluminum.
1985.1 944n/a
Old 10-04-2003, 10:09 PM
AFJuvat's Avatar
You over tightened or possibly broke the bleeder bolt (it is hollow and easy to break)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-05-2003, 05:20 AM
SoCal Driver's Avatar
Supposed to me a brass/copper washer under the head of the bolt.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-05-2003, 09:21 AM
