ds475's Avatar
Send a message via AIM to ds475
silicone hatch reseal
after cleaning off all of the old glue off the hatch and hatch seal, could i just use silicone? or do i need that special glue...?
what is the name of the old glue remover by 3M?
what is the name of the glue you use to reseal by 3M?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-05-2003, 02:30 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
You cannot use silicone. You will do all the work and as soon as you close the lid for the first time, it will separate again
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 10-05-2003, 02:51 PM
SoCal Driver's Avatar
You have to get the 3M stuff made for gluing in windshields.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-05-2003, 04:35 PM
3m "window weld" is what I use. $15 a tube at your local AUTO shurwin williams paint store. You also have to get a HEAVY DUTY calk gun... the $12 one at home depot. The little cheepy ones just bend under the pressure you need to push that sutff.
Travis
Rennbay, inc. 888-739-7839 x944
Old 10-06-2003, 06:27 PM
ds475's Avatar
whats the glue remover called used to take off old glue?
'82 928S
Old 10-06-2003, 08:32 PM
Project944's Avatar
You could use Urethane (caulking gun applied) or Beuttle (sp?) tape (comes in a roll) 3M makes both I believe.
83 944 n/a
Starting a project. Hopefully not in over my head
Old 10-07-2003, 03:36 PM
A scraper.
Old 10-07-2003, 03:53 PM
Roger Hall's Avatar
It sounds like you are talking about the metal trim around the glass, but I am not sure. I have heard that if the glass has separated from the metal frame its hard to fix.
If you are talking about the rubber seal around the body, I did not have any luck glueing it. It actually requires no adhesive. I did not realize this untill I purchesed a new one since the old one had been previously glued. I thought more adhesive would fix the problem, but I never could get it to seal properly.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 10-07-2003, 06:12 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Gerneral Purpose Adhesive Cleaner is the name of the stuff to get the glue off. in the shop where we installed sunroofs we called it prep solvant. part number is 051135-08984. i love the stuff. didnt hurt the paint when we used it either. when we really needed to clean something that wasnt around paint we used paint thinner but thats risky. you can buy a can od it at NAPA.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-07-2003, 06:27 PM
repoman's Avatar
I had very good luck installing 1/4" JC Whitney foam rubber weatherstrip alongside my new hatch seal.
You shouldn't need adhesive on hatch weatherstrip
'84 944 auto stock
Old 10-07-2003, 10:15 PM
REPO,
This is the actual glass hatch fitting inside the metal edging, not the weather stripping
3-924's (Sold)
1967-912 (Traded)
Old 10-08-2003, 09:36 AM
ds475's Avatar
isn't it the metal stripping that typically leaks, or is it just the seal?
'82 928S
Old 10-08-2003, 12:56 PM
Normally leaks occur at a broken/cracked seal unless the frame is separating from the glass. Then there would be a hole for the water to come in.
3-924's (Sold)
1967-912 (Traded)
Old 10-08-2003, 01:26 PM
ds475's Avatar
do a lot of hatches only leak because the actual rubber seal is bad?
'82 928S
Old 10-08-2003, 08:18 PM
repoman's Avatar
Gordon,
besides seals my hatch was separating from frame at top edge. I put tape under seam inside then filled gap with flowable hardening silicon; worked well
then cosmetically hid repair; easier to do than removing and clamping
to DS, my guess is a bigger problem with bad rubber is exhaust in cabin
'84 944 auto stock
Old 10-08-2003, 10:30 PM
