Send a message via AIM to Jason White
Porsche Crest Fuse box diagram
I need a picture with a description of the fuse box and relays to a '87 924S. Does anyone know of a website I can get this information off of. Or maybe someone could email me this information. I have looked all over and don't want to wait for a manual in the mail. Your help will be greatly appreciated.
JW
1987 924S White
-daily driver w/86k miles almost stock-
1971 914 Red
-doesn't see road much-
Old 10-05-2003, 03:17 PM
SoCal Driver's Avatar
www.frwilk.com
The fuse bock layout is the same as the early 944's.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-05-2003, 04:26 PM
Thats what I figured just needed to know for sure. Thanks
JW
1987 924S White
1971 914 Red
Old 10-05-2003, 04:28 PM
What problems are you having?
Old 10-05-2003, 04:33 PM
I have few electric problems. But first I need to switch out all the fuses, the previous owner was using all bus fuses.
1987 924S White
1971 914 Red
Old 10-05-2003, 04:37 PM
The other problems I've been having may just be ground problems. I have searched the wiring harness for broken wires and what not. The major problem is with the headlight switch not working. The parking lights work but that's it, no headlight motor or headlights. So you have to open up the headlights manually and use the flasher lever.
1987 924S White
1971 914 Red
Old 10-05-2003, 04:43 PM
And then there is the climate control. The climate control works intermittently and when you have the flasher lever pulled back.
1987 924S White
1971 914 Red
Old 10-05-2003, 04:46 PM
Bus fuses? The fuses for the 944 are the pointed end ceramic with open bus. The color of the ceramic indicates the amperage. Usually just a good twist will knock off the corrosion at the ends of the fuses.
There is a relay on the headlight motor. If the rubber boot is missing it does not take long for the relay to go bad and you have to manually raise and lower the headlights.
Then you may not be getting voltage past the headlight switch. These tend to go bad too.
Pelican has useable schematics for your car. For the headlight circuits it's the same as the early 944's.
Old 10-05-2003, 04:48 PM
