What do mean flip around?? Please help!
When you guys responded about my CV joints you said flip around?? Did you remove the joints and put them on opposite ends of the axle or just put the axle on opposite of what it was??
Help Brock |
this is something for obin...
------------------ 85.5 Porsche 944 |
dmac
Member posted 06-08-2001 07:55 AM -------------------------------------------------------------------------------- To remove the CV's you will need the infamous 12 point tool - Allen and Torx do NOT work! You can swap the inner and outer CV's (or left and right CV's) to reverse rotation and even out the wear. I did not bother to do this as my CV's are good, and they are pretty cheap to replace when the time comes. |
Just turn the axel around.
| All times are GMT -8. The time now is 03:59 AM. |
