Wolf1's Avatar
WOW, thats alot of time.
I was just looking at the flat rate time for replacing the clutch in the 951. The time is 15.6 hrs!!!!! does it "really" take that long? This is looking more like a weekend project rather than an after work project...
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 10-06-2003, 10:34 AM
Scott R's Avatar
Re: WOW, thats alot of time.
It can take that amount of time and then some. Basically the bulk of the extra time on the Turbo is the crossover pipe. If you have never had it off before then be ready for a fight. You have to disconnect at the headers, and at the turbocharger. The turbocharger side is a real PITA!
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-06-2003, 10:50 AM
Techmonkey's Avatar
When where you planning on takling this maybe I could come by and help get in the way
83 944 with 87 engine 5-speed LSD
burnned
Old 10-06-2003, 01:01 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Even the NA takes arounf 11 hours or so. I guess they never planned on the clutches outlasting the cars.
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 10-06-2003, 01:52 PM
Wolf1's Avatar
Looking through the little hole in the bellhousing while the clutch is being depressed. I see some slop between the release fork and pivot shaft.
I see the clutch fork bearings are listed as available but what about the shaft that they turn on? Are these usually worn and need replaced or is it just the bearings that wear.
75 914 - Undecided.
Old 10-06-2003, 05:49 PM
Scott R's Avatar
No the pivot shaft should be fine, just get new needle bearings. You may also need a new release fork if its too badly grooved on the ends.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-06-2003, 06:03 PM
SidVicious's Avatar
Re: Re: WOW, thats alot of time.
Yep. The whole job is a PITA, Scott just pointed out the most fun part. A helper will REALLY come in handy, too.
Old 10-07-2003, 09:17 AM
Chris_924s's Avatar
Especially if the helper looks great in a Bikini...
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 10-07-2003, 10:19 AM
