Electric-oil pressure trouble
My gauge never worked. Always went to max when key on. (even when disconneted). I installed new sending unit and it worked for about thirty seconds. I'll check fuses tonite. Any ideas? Thanks!!
'87 944 Maraschino Red Metallic Euro delivery...five speed
Old 10-06-2003, 12:40 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Short?
I think when the sender fails and causes the full up thing, it is an internal short... check all the wires/etc...
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 10-06-2003, 02:23 PM
Send a message via Yahoo to Cebu
85.5 944na..Had the problem of indicator pegging at 5-bars with ignition on. Replaced the wiring from just below the AFM under air inlet duct, down to the oil pressure sending unit..problem solved. The wiring was shorting inside the conduit.
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 10-06-2003, 03:22 PM
Ok Cebu, that sounds about right. Brad too. The valves had all been replaced so I wonder if the short could be up under the intake. But like you say Cebu, my wires going to the sender are looking tired. They are wrapped in black tape saturated with oil. THANKS!
Old 10-06-2003, 04:22 PM
