Proud to be Porsche
After just recently becoming a proud owner of my first Porsche - a White 85' 944 with 53k original miles, I can honestly say that this car is one of the funnest cars I've ever owned, past company including Corvettes and Mercedes. Its astonishing to me that a car almost 20 years old gets so many looks and compliments. All that aside, this thing is built solid,runs strong, handles great and the engineering is strait forward.
On a different note I am looking for a bit of advice on rear tires for the stock phone dail wheels, Tire rack said that although I could fit 265/50/15 on the back, they would adversely affect the cars handling. My question is what is the best size to upgrage to on the rear without compromising handling or the stock geometry?
Old 10-08-2003, 09:59 AM
265/50 won't look right. That is too wide..I would go 225/50/15's if I were you.
Old 10-08-2003, 10:10 AM
SoCal Driver's Avatar
53 original miles?????
Really?
Note the odometer is only five digits in the early 944's with the square dash. Six digits with the later 944's with the modern dash. Could be 153,000 miles.
Still I strongly suggest having the timing and balance shaft belts changed if they haven't been in the last two years. If/when these break it's $1,500 to fix the bent valves.
Post some pictures!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-08-2003, 10:12 AM
ds475's Avatar
Send a message via AIM to ds475
is that 53 or 53,000...?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-08-2003, 10:45 AM
Your reaction to the miles was my own, until I looked over the car and could'nt find any indication of aging-incidentally, I called the first and only owner and he reassured me of the miles and history of the car. I was also lucky enough to get all the service records at purchase, and was relieved when I found the dealer receipt for the timming belt etc. replacement at 37k. I must say, its great to have a resource like this forum to find out about possible/common problems.
Old 10-08-2003, 10:56 AM
pic
Old 10-08-2003, 11:13 AM
thamlin000's Avatar
Wow. Look at that air dam. Straight and true.
Your 944 is a 1985.5, judging by the flush mounted windshied. 85.5+ 944s have a more modern interior, flush and ant. mounted windshied, stronger hvac, and an all-aluminum suspension.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 10-08-2003, 12:06 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Nice catch....
Enjoy!
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-08-2003, 01:16 PM
ds475's Avatar
that air dam takes such a beating. when i got mine, and saw how bad it was, i couldn't believe how someone could be stupid enough to screw it up that much... until i pulled over parking lot blocks or sidewalk, and heard it scrape...
it's a lot lower than you expect...
'82 928S
dj_yen's Avatar
265's are too wide in my opinion. 250's max and you don't even need that much rear rubber unless you got a turbo. the more rear rubber you have in proportion to the front, the more understeer you will have. having too wide of rubber for a car not meant for it can reduce car steering feel and sensitivity. wide rubber is damn expensive also.
also staggering your tire widths can be a pain in the ass when it comes to tire life and flats.
too me the easiest thing you can do to get better handling feel (besides restoring the car to it's original condition) is bigger sway bars.
944 NA 5-spd, Red, 1987 - 2005
May She Rest in Peace
944 Turbo 5-spd, Black, 1987-present
70k miles
Old 10-08-2003, 01:50 PM
I read it wrong. 53,000 miles. Really nice late model 85.
Some have all the luck.
Old 10-08-2003, 02:00 PM
daveimme's Avatar
Send a message via Yahoo to daveimme
How much did you pay for this? it does look nice, but pic is kinda dark.....
83 944 N/A 5 sp. (mine)
90 Acura Integra auto (sons)
2000 Honda Odyssey EX auto (wife)
83 Suzuki LT 125 (4 wheeler) (wife)
92 Honda XR 80 (son)
97 Honda CR 125R (son)
98 Honda CR250R (MINE)
2000 Kawasaki KX 65 (son)
2003 Honda XR 50 (Son and daughter)
Old 10-08-2003, 02:16 PM
entertaining the idea
UconnTim97's Avatar
My 83 only had 60,000 miles on it when I bought it. Like, mac10, I doubted it until I looked at all the service records from the dealer which listed the mileage when the work was done and carfax reports.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 10-08-2003, 03:02 PM
Some1else's Avatar
Very nice 944!!
As for tire size, you are going to get many different opinions. There are the folks that will say that because of the weight ratio of 944s you should keep the same size all the way around. Others may argue this. I first would ask, what do you want to do with your new car, DE events, autoX, street/sport, or daily driver? Personally mine is a summer driver, and I have 7 front rims, and 8 rears. Because of this Im putting 215s front, and 235s rear. Also I dont like how easy the backend breaks loose in tight corners when I try to accelerate through the corner. But thats me, and Im sure I will get much abuse for say that!
I will say this, if you are going to go with a different size front to rear, keep it at 20mm. Also, IMO, there is no reason for going any larger then 235s on a stock 944NA.
83 944N/A Summer
88 4Runner Winter
Give me a D Give me a Y Give me a S L E X I A!!
What do you get? Dilex.. Dislax.. Dylsia AHH F**K IT!!!!!!
Old 10-08-2003, 04:15 PM
Custom User Title
rammstein's Avatar
Awesome car dude- It seems all you need to do is continue staying on top of the maintenance and you have a fantastic ride. Enjoy it.
Old 10-09-2003, 06:12 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
hey some1else, im with ya on the not liking the backend breaking loose! how do you stop that... while continuing to accelerate?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-09-2003, 10:37 AM
