Smoke from the exhaust header
I need some guidance on this one. I know that I have a leaking front camshaft seal that causes a small amount of oil to drip on the front of the exhaust header and burn.
Just recently, there is quite a bit of smoke now coming from the back of the exhaust header (near the firewall). Would this be the rear camshaft seal or could it be the camshaft cover gasket leaking. I can see some oil on the camshaft cover just above the #4 exhaust header bolt (last header bolt before the firewall). I suspect that the oil is dripping down on the header and causing all the smoke.
Any help on this would be appreciated.
1983, 944 with 114K miles.
Old 10-08-2003, 04:20 PM
SoCal Driver's Avatar
Cam shaft seal and cover.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-08-2003, 05:06 PM
Will be handy to send smoke signals though....
As usual Hugh is on the money.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-08-2003, 05:10 PM
Had to redo the cover after the first valve job.
Old 10-08-2003, 05:22 PM
