scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Exclamation Need bolt sizes asap!!
well i think i found out why when i turned on the a/c the engine shook quite a bit. one thing that i knew about what that the adjusting strut was broken at the point where it connects to the a/c compressor. then when i took that off i found out that was the only thing holding the compressor in place!!! the front mounting bolt was snapped and the rear is missing!!! i am really starting to wonder how the PO must think...
anyways i was wondering if anyone could give me the correct sizes of these 2 bolts. they are the two that connect the a/c compressor to the engine. Thank you!
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-08-2003, 03:29 PM
The front one is part number 900 082 088 02, it's a different thread bolt to a normal M10 so make sure you get the correct one!! You need a
M10 x 1.25(pitch) x 50mm (length).
The rear bolt is part number 900 074 139 02, this is a normal DIN thread so any M8 x 55mm bolt will do.
Your local Porsche dealer is unlikely to have these bolts. The M10 one from Porsche is expensive. Go to a good fastener shop.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-08-2003, 05:08 PM
thank you very much, im going to go to the bold shop tomorrow.
Old 10-08-2003, 05:41 PM
