dzachry's Avatar
Send a message via AIM to dzachry
944 High Idle
OK guys I know I have seen this here before but I can not find it. My 84 944 has a high idle between 1000-1200 I know this is to high. I need to get it smoged next month so I need to get the idle down. I saw the set screw on the throtle body but this made no change. What is the trick or does anybody have any ideas on what could be wrong.
David Zachry
84 944
Old 10-09-2003, 01:30 PM
SoCal Driver's Avatar
Vacuum leak somewhere if the screw doesn't change it. Is there an o-ring around the idle adjustment screw?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-09-2003, 03:24 PM
dzachry's Avatar
OK you got me what Oring and what Idle adjustment screw are you talking about. I only saw the adjustment screw that stops the throtle for going to far back????
HELP!!!!!!!
David Zachry
84 944
Old 10-20-2003, 05:04 PM
dzachry's Avatar
HELP
HELP!!!!!!!
David Zachry
84 944
Old 10-20-2003, 05:05 PM
