-   -   guages... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/130931-guages.html)
scheistermeiste 10-09-2003 04:06 PM
guages...
hey why does everyone else have that guage that says how many miles to the gallon they are getting un the tach and i dont??? i feel so left out :-(
TCMdocs944 10-09-2003 04:49 PM
924 ?
Nobody trust that stupid guage anyway..
It wiggles around more t'in a three legged dog in a pile o ants.
ds475 10-09-2003 06:22 PM
that gauge is a piece of s***, when you are at idle, you get 60 mpg, and when you just barely touch the gas, it goes to 0. retarded/gay gauge.
1.2gees 10-09-2003 06:46 PM
The gauge reads hours/gallon when you're under a certain rpm (or was it speed), but yes I agree it's not a very usefull gauge but it should be accurate if everything's stock.
Ahmet
UconnTim97 10-09-2003 06:49 PM
My freinds new Lexus has the same gauge. It seems to be just as active as the one on my car. It doesn't seem to be too useful, but it is a fun gauge to have none the less
lousailor 10-09-2003 07:48 PM
I'm willing to trade mine in for a plain tach, but since I'm upgrading the front suspension I'll have to look into a late tach as I won't be able to drive my current one witht the left wheel. Anyone know what else I'll need to install the electric version?
Buddy 10-10-2003 03:35 AM
You're driving the tach from the front left wheel? Hmm...let us know how that works out for you.
jts924s 10-10-2003 04:53 AM
I don't have a MPG gauge either. I don't recall seeing it mentioned in the owner's manual. I have seen it in the 924S dealer brochure. Maybe the CASIS (that irritating upshift arrow) relaced the MPG guage.
lousailor 10-10-2003 07:23 AM
jts924s, Unfortunatley I have both in my early '85, and that dang arrow is annoying.
Buddy, the '87 924S like the early 944s uses the stamped steel control arms up front (i.e. early offset) and the Speedometer is driven by a cable into the front hub (I mis-spoke in the previous). My understanding is that on the later cars, the speedo is driven through the transaxle. I'm wondering if that means I'll have to update my rear end as well?
lousailor 10-10-2003 07:27 AM
OBTW here's a nice plain Tach on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2435315441&category=33 679&rd=1
about the same that I paid at my local salvage shop when my speedo went.
SoCal Driver 10-10-2003 08:12 AM
The tach's on the 944's all come off of the coil wire from the DME.
The fuel use gauge is driven by a signal from the DME (it seems to be the injector pulse width) and a hall effect sensor off of the back of the speedo on the early 944's.
The 924S is basically an early 944 with out the fender flairs. Thus the speedo comes off of the left front well via cable. So you could have the fuel use gauge if it was wired in.
The miles per gallon is for 5th gear -- stock tires. The gallons per hour is for any gear.
I seldom pay any attention to mine. It's fun to show your passenger that you are getting over 40 miles per gallon at 80 MPH -- when you let off the throttle just a little when going down a slight hill.
Nigel Haslock 10-10-2003 08:37 AM
My original Owners Manual shows the gauge but it is missing from my car too. What was Porsche thinking?
1.2gees 10-10-2003 08:44 AM
There should be a disclaimer on your owners manual saying that not all shown options may be installed on your car...
Also, the gauge is reading hours/gallon, not gallons/hour.
Ahmet
TCMdocs944 10-10-2003 09:51 AM
Hours per gallon?
Verruckt 10-10-2003 09:54 AM
Gauge envy, it's not pretty.
Surprized mine has one, since everything else was deleted on my car. No rear wiper, cruise, sunroof, ect.
SoCal Driver 10-10-2003 10:07 AM
You will have to get a tach with out it. Should save two maybe three ounces!
SoCal Driver 10-10-2003 10:14 AM
Ahmet
Made you look! Made you look!
Well I did have to go out to the car and take a look.
Clearly the top line of the gauge reads:
G/h
Looks like Gallons per hour to me.
Might be different in German.
scheistermeiste 10-10-2003 12:39 PM
ahhh thats a little shift arrow!... thing never worked for me... eh i guess ill fix it. if i dont then i have that thought in the back of my head of "... man i know not EVERYTHING is fixed..."
1.2gees 10-10-2003 03:08 PM
SoCal, I don't have my 84 anymore and I'm not a mechanic at the moment either, so I have no way of going out and looking at the gauge...
However I would hope that it shows hours/gallon, because otherwise it would be implying that it takes ~60gallons to idle for 1 hour, which is obviously not correct. Perhaps a german thing, or even a misprint, who knows.
Ahmet
BlueQuestTSi 10-10-2003 03:48 PM
It IS G/h for Gallons per hour, BUT...... It isn't pointing at the 60 mark, it should be pointing at the location were ".5" is marked, as in " Gallon per hour" :D
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
