Porsche Crest Flywheel lock, gear puller, other tools.
I've ordered the parts to do my water pump and all belts. (and heater valve) Where does the flywheel lock get installed, and is there such a thing as a universal one that any local wrench might have? Im gonna replace the rollers too.
'87 944 Maraschino Red Metallic Euro delivery...five speed
Old 10-10-2003, 07:10 AM
Scott R's Avatar
Don't know if there is a universal flywheel lock, other than using a screwdriver or pry bar. But the Porsche flywheel lock gets installed where the starter mates to the bell housing. Meaning that you remove the starter and bolt the lock using the starter bolts.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-10-2003, 07:27 AM
Thanks Scott
Old 10-10-2003, 01:08 PM
repoman's Avatar
Michael,
you use one starter bolt threaded into bellhousing and in the other hole use a bolt AND nut.
I couldn't find a nut to fit starter bolt so I just used a generic 3/8 bolt & nut.
'44 starter is very easy to pull; maybe mine was super easy as no slave cylinder to work around
Have a cut up coathanger to hang starter from. Also disconnect battery to avoid arc-welding
'84 944 auto stock
Old 10-10-2003, 10:13 PM
I guess I'll be looking for a f-wheel lock. I dont want to take any chances! Thanks for advice
Old 10-12-2003, 07:06 AM
