ds475's Avatar
Send a message via AIM to ds475
Strange engine clatter...
when my engine is at low rpms and high load, and i don't give it a lot of gas but try to accelerate deliberately, i get this clatter from my engine. i'm curious to what this may be, it seems to go away at higher rpms, or if i push the gas down harder.
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-11-2003, 12:25 AM
SoCal Driver's Avatar
The cam pulley has been know to come loose.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-11-2003, 12:40 AM
Scott R's Avatar
Is it in the engine compartment, or maybe your CAT is rattling around. CAT and exhaust shields like to make noise at low RPM's.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-11-2003, 07:51 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Since we are pulling at straws............. clatter = what ?
I will say rod bearings............
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-11-2003, 08:32 AM
Send a message via Yahoo to Cebu
low octane fuel..engine knock/valve chatter.. add octane booster or premium quality fuel
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 10-11-2003, 10:56 AM
I just diagnosed my clatter problem.
Sounded just like yours.
After EXTENSIVE research here on Pelican I was sure I had a lifter stuck/knocking whatever. But, I kept thinking the sound was like a loose/wobbly pulley. Checked behind timing covers, everything nice and tight. No leaks or loss of power. Just very intermittent "rattling" only at low/idle rpm's. Then I remembered my trusty mechanics stethoscope. Found out the waterpump vane impeller was worn where it meets the shaft yet the belts kept it tight enough not to "feel" a worn pulley. Strange though, I never developed the telltale waterpump worn out leak.
Hope this helps.
The folks here on the board are best.
87 944na
Old 10-11-2003, 03:24 PM
ds475's Avatar
it's not knock, it's a weird metal clattering sound, it's actually very hard to describe. but what i said about it ONLY happening at low rpms, high load (too high of a gear), and not a lot of gas from the pedal.
'82 928S
Old 10-12-2003, 12:34 PM
