TNT25169's Avatar
Send a message via AIM to TNT25169
Oil Pressure Problem
My oil pressure gauge is fine when I am driving but when my car is at idle, the gauge bounces around all over the place. I think it's my oil pressure sender but I'm not sure. It's not a big deal but it really pisses me off. Any suggestions on where I could get another sender and how hard it would be to fix?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 10-11-2003, 07:32 PM
Mine ticks about +/- 0.5 bar at idle when warm. I think it is the gauge. Could be a ground somewhere. I hate to say it but my clock is the best gauge in the car. Your wobble sounds worse than usual. If you know someone with a quality external oil pressure gauge you can hook it up and see what that says. New senders are about $45 from Pelican, gauges about $95. I would think changing the sender would be about a 4 on the PITA scale. You may have to drop the power steering pump.
'87 924S , sold.
'99 Subaru O/B, 62K on first timing belt. Could have gone another 40K.
Old 10-14-2003, 06:41 AM
