924S Auto-x Tire Size
I just purchased a 1988 924S Special Edition (M030) to go along with my 1985/2 944.
This may be better suited to the autocross board, but there probably isn't anyone there with an answer, so here it goes:
I am involved in stock class autocrossing, and have been using a set of 225/45-15 on my 944 (with the stock 7x15 cookie cutters). Does anyone know if these will fit within the wheel wells of the 924S using the stock rims? (6x15 front and 7x15 rear - phone dials with the later offset). It looks like there will be enough clearance on the inside (barely), but the tires might be sticking outside of the fenders. I have not changed the ride height yet.
Anyone here done this before?
Kaos
Old 10-12-2003, 01:31 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Kaos, I used to use 205 and 245/16" but rubbed in hard cornering. If going stock springs the 205's would rub on the front but with stiffer springs it no longer rubs. The 245's rubbed a bit with stock rear end and was solved with 968 adjustible rear sway and Koni yellows. Wheels are 7 and 8". Are you allowed any modifications to the suspension? If so, stiffen up, then determine what wheels/tires can solve the rubbing. PCA does not allow fender rolling without a change in class IIRC. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 10-13-2003, 05:07 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
COOL! youre the first other person ive seen with the same car as me!!! no sunroof or power options right?!
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-14-2003, 04:41 PM
Official Sponsor
vital-transform's Avatar
Hey, I too am curious to see if I can get a set of 7jx16 wheels with 215 55 16 tires onto the front of my 88 924S - anybody have any experience with the bigger wheels and tires on this model?
1988 - 924S Guards red, auto trans
Old 10-14-2003, 08:03 PM
I've got 7x16's on my 87 924S. They are the forged wheels from an early 928 with a 65 mm offset. I use a 5/16 spacer. A 13 mm spacer (1/2 in) would be better.
I run 205 55x16 Kumho MX's with no trouble front or back. Currently, camber is -.75 deg. I'm going to try to get to -1.5 deg front -1 deg back.
924S Bob (the other one)
Old 10-15-2003, 03:36 PM
Official Sponsor
sounds great ...yeah I have the same wheels and am going to try a 12mm spacer this week. 215 55 16 continentals on the 928 forged flat "garbage lid" wheels..happy to know that you were successful with this modification!
Old 10-15-2003, 09:14 PM
Hey vital, where did(will) you get 12 MM spacers?
Old 10-16-2003, 04:27 PM
Official Sponsor
Ah ha! I tried 2 other places and then good old **********.com out of Miami had them right there in there newest catalog! (page15)
$85. each with studs and bolts and if you haven't used these guys they are the BEST! lowest price and best selection that I have come across!
Also know their parts (oh yeah this is Pelican Parts board, oops..sorry but I don't yet get their catalog)
Old 10-16-2003, 08:03 PM
