SoCal Driver's Avatar
Originally posted by Porsche944
OK. Fuses, fans and relays are good. Temperature switch in the radiator is bad.
You have to use the temp switch from the 84. The two terminal one. Then again IF you have an air bubble in the top of the radiator then the temp switch will not see the coolent.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-15-2003, 01:52 PM
