pearldrum's Avatar
Send a message via AIM to pearldrum
Porsche Crest No more hard-starting!!
YES!!! I went to start my car this morning and it fired right up! The second I turned the key. I usually have to try turning it over 8 or 9 times, or use starting fluid. I also could have driven it right away, usually it has to warm up before it won't die. Trying to fix this problem we replaced, fuel pump, fuel rail, some lines, check-valve, injectors and a few other parts. We also let a shop look at it, they had no idea.
Yesterday we replaced the DME and the vacuum valve that goes under the far intake manifold tube. When I get a chance I'm going to plug my old DME back in to make sure that was the problem, I'm pretty sure it was. This is great...
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 10-13-2003, 04:38 PM
Roger Hall's Avatar
Congrats it must feel good!
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 10-13-2003, 06:13 PM
SoCal Driver's Avatar
Open up the old DME and resolder everything. Then you will have a second DME.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-13-2003, 06:42 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
if your not big on the soldering i can can do that for you tyler, but yeah really glad it worked for you, you seemed so happy about it this afternoon, now if only we could fix that suspension issue, then you would be closer to set, well clutch..
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 10-13-2003, 07:01 PM
