light front end
I have a question I was going about 130 and the front end was very touchy,kinda light and not very controlable, is there a fix for this that can pull the car lower to the ground at higher speeds?
Also when the car is warming up it sounds like i have a turbo, kinda a high pitch whine, it goes away when she is warm
and last is it hard to put nos in a porsche?
Old 10-15-2003, 04:46 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
"and last is it hard to put nos in a porsche?"
uh oh, here we go again
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 10-15-2003, 06:16 AM
daveimme's Avatar
Send a message via Yahoo to daveimme
I hope you were doing 130 on a track and not where Grandma, Grandpa, Mom, Dad, uncles, aunts and kids commute every day, huh?
Just tell me it was on a track....if not, then you're irresponsible.
83 944 N/A 5 sp. (mine)
90 Acura Integra auto (sons)
2000 Honda Odyssey EX auto (wife)
83 Suzuki LT 125 (4 wheeler) (wife)
92 Honda XR 80 (son)
97 Honda CR 125R (son)
98 Honda CR250R (MINE)
2000 Kawasaki KX 65 (son)
2003 Honda XR 50 (Son and daughter)
Old 10-15-2003, 07:08 AM
Tex Tex is offline
Tex's Avatar
whine is from your fan belts.
also these cars arent meant to be driven around 130 mph.
if your doing that, consider lowering it and adding a front spoiler/airdam type configuration.
yes nos can be added but why?
1981 Porsche 924
Click Here To See My Car
Old 10-15-2003, 07:26 AM
SoCal Driver's Avatar
As Tex (from Maryland?) says lower the car and get serious with some spoiler work such as a spliter and the covers (pans) under the engine.
I would add if you haven't had a front end inspection, shocks, bushings, tie rods, ball joints, then get one and fix all that is worn.
Nothing like a tight suspension!
What model and year car? How many miles?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-15-2003, 09:33 AM
On an old air strip not the highway. thanks for the concern though.
84 844 na 115k
Old 10-15-2003, 09:55 AM
The whine could also be your balance shaft belt. Mine does it when cold. Unless I keep the belt quite loose, it whines when cold.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-15-2003, 10:10 AM
Non Compos Mentis
Proper alignment is neccessary, of course, but also remember that at high speeds, any car will feel "twitchy". Things happen very fast, and a very slight change in steering will result in an unplanned lane change.
Do NOT overcorrect.
Old 10-15-2003, 03:13 PM
