fuel filter
where the hell is it? the owners manual says nothing lol
86' Porsche 944 N/a
Old 10-14-2003, 07:33 PM
Verruckt's Avatar
Passenger side, behind rear tire, by the fuel tank.
The crashes people remember, but drivers remember the near misses. Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 10-14-2003, 07:35 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
Back by the fuel tank. It should be just in front of it, toward the front of the car. A silver cylinder that is mounted pretty high. If you can't find it, follow the fuel lines.
edit:dial up...beat me to it...
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 10-14-2003, 07:37 PM
pearldrum's Avatar
Also, you should go get the "Haynes Porsche 944" shop manual. Should be available at local automotive stores for pretty cheap. It's not the best, but is pretty good at describing jobs like that.
Old 10-14-2003, 07:44 PM
winter-hater club member
nynor's Avatar
its a rather large cylinder. don't buy one at checker, as they try to sell you a "universal" type unit a that will require you to cut the fuel lines, etc. the correct one will have threaded fittings. got mine at the dealership because i was in a hurry
"COOL PRIUS!" - Nobody Ever
Old 10-16-2003, 01:29 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
yeah, get the mahle filter to replace it w/ its the best quality and it has better wrench space on it making the ob much much easier, been there done that make sure to have something ready to catch the fuel that comes out, and depressureize your fuel system first.... read the haynes manual!
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 10-16-2003, 02:56 PM
stray15's Avatar
Send a message via AIM to stray15
i have one for sale if you want it
Old 10-16-2003, 02:57 PM
TCMdocs944's Avatar
Rock---............I KNOW you have the haynes manual by now right?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 10-16-2003, 03:14 PM
nynor's Avatar
one more thing, you can depressurize the fuel system easily by removing the fuel pump fuse, with the engine off, and then running the engine till it dies... voila, no pressure. but be ready to catch the fuel coming out, as it is a lot.... or you can punch a hole in the filter both top and bottom with a nail... that way you get much more controlled leakage of fuel. but only do this procedure with the old filter
Old 10-16-2003, 03:20 PM
haha never thought of punching a hole, but just get a pan ready and wear your safty glasses!!!!, i cannot stress that enough, may need to use some pb blaster on the bolts too, they can be pretty bad, especially if the filter is 15 years old like mine was
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 10-16-2003, 03:58 PM
bearone2's Avatar
let's see, punching a hole in the fuel filter with a nail.
this could lead to being a darwin award recipient because of the spark, explosion and fire.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 10-16-2003, 08:21 PM
The fuel filter is located under the car, sorta next to the inner side of the rear passenger side tire. You can't miss it because it's a large silver color cylinder. You could also locate the underside of the fuel tank and follow the hose coming out from it to the filter.
If you raise the car and try to remove the filter, tie some shop towels around your wrists. You DO NOT want to get gasoline in your armpits, trust me. I'm not sure if what I did was right, but I took off that little plate that's screwed onto the side of the fuel tank (where the fuel pump is located) and pinched the hose in there with a wrench. It worked out pretty well. A LOT of fuel that has been packed into the fuel filter will drain out, it seems like there's an endless supply coming out.
Once you're done, it will also take a few cranks with the engine to get the fuel pumping through that massive filter again. After a couple tries, it should be pressured again and you'll be good to go.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 10-16-2003, 09:28 PM
MrPants's Avatar
if anyone in the history of the world has ever sparked a gasoline fire by punching a fuel filter with a peice of steel ill eat my hat.
also if you have an oil pan to drain the gas into, it works much better than a towel as there is a lot of gas that will pour out. the towel will reek of gas forever. (and i speak from personal experience: do not put the towel in the wash with any of your clothes)
84 944 Non Alcoholic
Old 10-17-2003, 12:53 AM
The fittings are usually quite tight. So here is my advice. Place two wrenches on the fittings one to turn while the other holds the filter side. Let them form an angle of about 10-20 degrees. Then squeeze them together. The fittings have the tendency to suddenly come loose. If you are using your arms instead of a hand squeeze, you will smash your knuckles or an elbow when they suddenly loosen.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-17-2003, 04:22 AM
nynor's Avatar
someone please explain to me how an explosion is going to occur using the nail trick... explosion takes oxygen, no oxygen in the filter, thus no explosion... lots of criticism, not much though sometimes.
actually, less chance of darwin award due to much more controlled leakage of fuel.
Old 10-17-2003, 07:35 AM
nynor's Avatar
also, i don't think you have to crank the engine to pressurize the fuel system. turning the key to on position will run the pump until the system is pressurized. you will hear the pump running and then shut off, at which point you are ready to fire it up.
Old 10-17-2003, 08:41 AM
When you grind steel with a grinding wheel, there is a huge amount of heat generated. The particles of metal being ground off by the wheel are very hot and are in our visible spectrum range so we perceive it as 'red hot'. We see the sparks because the particles are glowing as they are shot out from the wheel. Metal glows red at about 1200 F. Some of the carbon in the steel also burns during the grinding process enhancing the sparking. That is why steel sparks when struck.
Aluminum is a much softer metal. Because it is softer, far less heat is generated during a grinding process. The amount of heat generated is relatively low so the part does not get nearly as hot and, hence, there are no sparks. Aluminum is also a far better conductor than steel is. Thus the small amount of heat generated tends to dissipate into the surrounding metal more readily than with steel. Aluminum conducts heat 6X better than carbon steel.
I tend to agree that punching a hole in the filter with an ice pick would not be dangerous because it is ductile aluminum casing.
The aluminum is not hard enough to cause the steel to spark. The aluminum, itself, won't spark.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-17-2003, 08:53 AM
SoCal Driver's Avatar
Just turning the key on does not run the fuel pump. You have to crank the car.
The fuel pump runs continously when the engine is running. It shuts off if the rpms on the engine drop below 200 or if you turn the key off or if the fuse blows.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-17-2003, 02:55 PM
nynor's Avatar
check
Old 10-17-2003, 03:56 PM
bearone2's Avatar
MRPants:
when you are willing to punch a hole in the filter with a nail on your next fuel filter change please give me a little lead time, a couple of weeks or so and i will fly to dfw to watch you do it.
nynor:
earth is a class"M" planet, 78% nitrogen and 21% o2 and it's not the o2 in the filter that'll get you, it's when the spark, fuel and the o2 on the outside of the cannister start playing together.
i'd offer to fly to watch you do it also, but slc is too tough to get to for me.
Old 10-17-2003, 09:54 PM
