scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Question ac alt drive belt
is it possible to over tension the drive belt for the ac and alt? i finally got that adjusting strut fixed but one side of it i couldnt get the nut to loosen so i could adjust that side(side that faces the passenger side of the car). when i put it back on i put it on tight but it wasnt like the hardest thing to stretc it enough to put the bolt on the other side in. i was just asking because i noticed my engine doesnt rev nearly as quickly as it used to. another thing is now the ac compressor is actually bolted down and has the strut attatched. before the front bolt was snapped in half and the rear was missing and the strut eye was broken at the compressor.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-15-2003, 04:46 PM
The alt and ac drive belt has to be a lot tighter that your average belt.
That means tight, so that when you push it with your thumb there's hardly any movement. It has nothing to do with the revs.
Chat with SoCal about your grammar.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-15-2003, 06:42 PM
SoCal Driver's Avatar
The threads on the strut jack bolts are right and left hand. You were trying to tighten a left hand thread. Use some carb cleaner on them and get a drop light under the car for a close look.
Loosen the bolts on the ends before you twist the center. Be sure to tighten the bolts on the end when are through with the center.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-15-2003, 07:14 PM
What? Me?
Old 10-15-2003, 07:15 PM
Yes, you are more familar with the American grammar.
By the way, always loosen the AC compressor mounting bolts whan adjusting the belt..that's why they snap or fall out in the first place.
Crank the engine over a few times after adjusting, the belt loosens
sets into the grooves. Then tighten the AC compressor mount bolts.
Old 10-15-2003, 07:28 PM
Guess I can blame that on my mom and her getting me to read at four. Also throw in about six years of drama. Even then I still get butterflys at going on stage or public speaking. Don't when giving an engineering sale pitch to a board of directors for a millon dollars of automation.
Now if I could have learned to spell.
Old 10-16-2003, 07:32 AM
on the passanger side nut do i turn it to or away from the center piece? i tried spraying tons of wd40 on it and turning it bothways. it turned only slightly in both directions and tring to figure it out hurt my head too much... im special :-P
Old 10-16-2003, 11:15 PM
AFJuvat's Avatar
Originally posted by scheistermeiste
... im special :-P
So you ride the short Porsche to work?
Forget WD-40 Get PB Blaster Spray it down and let it soak. Look at the threads on each side of the tensioner and determine which way you have to turn it to loosen.
After loosening teh AC compressor mounting bolt, you can just take the tensioner off and work on it in a vice as well.
AFJuvat
"grammar and spelling I gots, typing on the other hand, kicks my ass with alarming regularity"
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-17-2003, 05:59 AM
yes... i admit it.. i do ride the short porsche to work. (mines got no back seats)... so if the threads are in an slanted upward i turn it which way?..
Old 10-17-2003, 04:27 PM
