ds475's Avatar
Send a message via AIM to ds475
Do our cars heat up a lot after we turn them off?
I was wondering, because I know noticed my car heating up from 1/2 to 3/4 after shutting off the engine, even with the radiator fans still on (they're on a plug... but that's another story) and another big ass shop fan blowing on it from the front with the hood open.
I don't race home either, I always make sure to give my car a warm down session. Is that normal?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-16-2003, 08:19 PM
bearone2's Avatar
the water will get hotter and expand because the engine isn't running and the water isn't being cooled by air flow coming over the radiator.
the fans will cool it down if they come on properly or with your plug arrangement.
my car runs at the 1st line and if i shut it off and go into a store for 5 minutes, come out, restart, the temp will get up to the 2nd line but will come down to the first line because of airflow over the radiator with movement or the fans should come on and pull the temp down.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 10-16-2003, 08:29 PM
ds475's Avatar
typically, my running temp is 1/2, up to 3/4 run hard.
'82 928S
Old 10-16-2003, 09:33 PM
Manute's Avatar
bearone is right,water stops moving and then builds heat,that´s why fans usually run for a minute after engine is stopped. I´ve observed it in every car,but specially in my 951,which is a heat machine!
If you stop the engine at 1/3,and temp rises to 3/4,just try to start the engine again...you´ll see how temp drops again in seconds.
85´5 951
Old 10-17-2003, 12:23 AM
Send a message via Yahoo to Cebu
Check this link: http://www.geocities.com/MotorCity/Downs/3837/thermosy.html
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 10-17-2003, 08:29 AM
winter-hater club member
nynor's Avatar
your temp gauge reads hotter after the water stops moving because it is then absorbing the heat from the motor and not getting cooled at the radiator. because the temperature sensor is at the top of the head, it is actually reading the temperature of the water, not necessarily the core temperature of the engine. thus, when the water is no longer circulating, the coolant rises to the core temperature of the engine.
its all good.
"COOL PRIUS!" - Nobody Ever
Old 10-17-2003, 08:35 AM
SoCal Driver's Avatar
Your temp gauge sender is on the engine.
The fan temp switch is on the radiator.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-17-2003, 02:43 PM
nynor's Avatar
you might want to check that again.... its on the head, i just replaced mine.
Old 10-17-2003, 03:57 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I hate to disagree, but it's in the block.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-17-2003, 08:05 PM
nynor's Avatar
um... the temp sender that goes to the temp guage is in the head... but, for the sake of this little argument, i am going to go look again... be right back.
Old 10-18-2003, 08:58 AM
nynor's Avatar
ok, my bad... it is in the block, technically, about 1 centimeter below the head. however, everything else i stated is correct, regarding the temperature being the temp of the water, because the sender is on the outside of the block with a water jacket between the sender and the actual source of the heat. i apologize for my one centimeter mistake.
Old 10-18-2003, 09:01 AM
todwic's Avatar
agreed
'86 951
Old 10-18-2003, 04:34 PM
nynor's Avatar
hey, todwic, i think our cars are the same color, or very close... i was looking at your web page
Old 10-19-2003, 06:30 AM
todwic's Avatar
Hellbronze? I like it! Kinda ties in my location.
'86 951
Old 10-19-2003, 09:57 AM
