ds475's Avatar
Send a message via AIM to ds475
With new fuel regulators can you increase performance?
with new fuel regulators, can you increase performance in any way? is it worth the cost?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-16-2003, 09:39 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Not likely, not w/out other (significant) modifications on your car, unless the current one isn't functioning as it was designed to.
Ahmet
Cheers!
Old 10-16-2003, 10:22 PM
AFJuvat's Avatar
Here is how the fuel system works on the car
(FR Wilk can offer a more detailed explanation, but this should suffice for the information you are looking for)
Fuel pressure is maintained at a constant by the action of the fuel pump, fuel pressure regulator, and fuel pressure dampener. The fuel pressure in the car does not change anywhere along the accelleration\power curve.
The DME controls the amount of fuel entering the cylinders by controlling how long the fuel injectors stay open on the intake stroke. Simply put, the longer the injector stays open, the more fuel you get.
The DME determines injector timing based on throttle position, air flow, engine temperature, altitude, (and on US models) emmissions, and finally engine speed.
In order to get any significant gain in performance, you would also have to increase airflow to the motor where the DME can "see" the increased airflow.
Bumping the fuel pressure without adjusting the other variables will likely result in an over-rich condition. causing the DME to try to "lean out" the car - shortening the injector pulse.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-17-2003, 05:52 AM
SoCal Driver's Avatar
So there!
Isn't it great where you can get the same performance increase wither you spend $100 or $1,000?
You want more performance buy a turbo.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-17-2003, 08:06 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Originally posted by SoCal Driver
So there!
Nanner nanner.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-17-2003, 09:20 PM
Ebs Ebs is offline
My mechanic suggested we put in a high pressure Bosch fuel regulator to try and take advantage of the other mods and even trying and get the engine to run slightly cooler. To be honest, the impact is at best very modest (ie, hardly noticeable) in both performance and cooliing.
Save your money.
1986 951 Euro spec model
Anthracite on black
105,000 km
K&N, Lindsey Boost Enhancer, chipped, oversize fuel regulator
968 Club Sport anti sway bars
Adjustable Koni Yellows
Fuchs alloy : 9 inch rear, 7 inch front
2.5 inch stainless steel exhaust
1984 928 S2 (Jap spec)
1977 Mazda 323 - hard core tuned
Old 10-18-2003, 06:30 AM
least common denominator
scottmandue's Avatar
Yeah but if you chrome plate your fuel regulator and add a turbo exhaust tip you can add about a hundred horsepower!
2019 Kia Stinger 2.0T
1995 Miata Sold
1984 944 Sold
A lie can travel halfway around the world while the truth is putting on its shoes.
Old 10-18-2003, 09:15 AM
