Fuel Pump
I think i have a problem with my fuel pump...I jumpered the relay 30 with 87 and i never heard anything kick in. The car won't start, but it will when you spray starter fluid in the intake. Can somebody tell me where the fuel pump is located, and help me out with some ideas of what i can do make sure that's what it might be?
Old 10-17-2003, 11:43 AM
Autobahn Garage
The fuel pump is back by the right rear wheel, Check for continuity from the relay to the pump.
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 10-17-2003, 02:16 PM
SoCal Driver's Avatar
Also check the fuse.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-17-2003, 02:57 PM
The pins to run the fuel pump are 87b to 30.
87 to 30 powers the DME and injectors.
Old 10-17-2003, 07:17 PM
