Does anyone know where to get metric fittings for braided steel lines? I need to replace the rubber fuel lines in my '78 924 but I can't find the fittings I need. I need 10mm banjo fittings and bolts this is the one I can find. 15mm banjo fittings (I think, I'm having a hard time measuring them). I also need a fitting that kind of looks like a flared fitting but it is backwards the pipe has the male end and the fitting is the female end the male end seems to be soldered on to the end of the pipe. There are 2 diffrent sizes used but I don't know how to measure them one is used on the accumalators and the other is used on the fuel distribitor. Thanks.
I have a '66 911 and had some braided line made for the oil system a while ago at Kaman Industial in Phoenix Az. They have a wide selection of other metric fittings and some hose. I hope that I have been of help
Threesticks 66 911 86 951 |
