Angry Questions on a 944 clutch job
I am having trouble with the release lever shaft. I have removed all but two of the bell housing bolts and I have removed the release lever retaining bolt. Now I am tackling the seized release lever shaft but its being a pain in the ass and not budging a bit. I might try a torch but I want to know if anyone has had this problem before and found a good salution.
Cael
Old 10-19-2003, 12:47 PM
SoCal Driver's Avatar
Lots of penetrating spray!
And a slide hammer.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-19-2003, 03:54 PM
Scott R's Avatar
I used a length of copper tubing that was larger in diamater then the rod. I then put the bolt with a few washers through the pipe, this created an extractor and it pulled the tube right out.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-19-2003, 06:15 PM
thanks
thanks for the help.
pin extracted and clutch job successful.
Old 10-30-2003, 09:36 PM
