Scott R's Avatar
Post Air/Fuel adjustment
I have read some of the archive posts and seen that you can do a home air/fuel check kit with a 3 wire O2 sensor, I have an 85.5 and I know from doing the clutch that it has a two wire. Does anyone have the PN# for the three wire? Also is there a way to make a check guage that I don't have to mount in my passenger cabin? As some of you know I have a supercharger on mine and I just can't get the air/fuel set right. And I don't think the Porsche dealer will set it for me due to the heavy level of modification my 944 has.
Old 07-01-2001, 11:17 AM
wolfrpi's Avatar
Arrow
go to pelican parts and get a 4-wire sensor for about $35. Get an air/fuel monitor anf injector monitor from Lindsey racing for $99. Also, pick up an adjustable FPR. With the FPR you can dial in your richness, along with the adjustement on the air mass metet.
Erick
Old 07-01-2001, 11:33 AM
wolfrpi's Avatar
Post
Although I'm not sure if the mass meter adjustment will afect high rpm mixture, the FPR definitely will
Erick
[This message has been edited by wolfrpi (edited 07-01-2001).]
Old 07-01-2001, 04:14 PM
