bearone2's Avatar
Question instrument cluster gremlins
i traded out the speedo yesterday, had a bad odo and both worked when driven.
i checked the lights last nite, park and full on(key on, headlights up/on) and only the fuel gage, oil pressure, clock, rear defroster button, fog light button come on.
turn signals, hi/lo beam, emergency flashers work.
this is on the fuse for the license plate lite and it works.
i was also dinking/douching with the turn signal/wiper switch as i've had an intermittent problem of the wipers coming on when they want to.
i see something close in haynes schematics about the turn signal ground but not sure if it's tied into the cluster.
any ideas?
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 10-21-2003, 06:12 AM
SoCal Driver's Avatar
Use the schematics in the FWSM.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-21-2003, 08:26 AM
winter-hater club member
nynor's Avatar
did you remember to put the little lights back in place on the back of the speedometer, etc.? if i am not mistaken, this is the same setup as the 83, if your signature line is correct and you are driving an 84.
also, the light bulbs could have come unseated/damaged by all the commotion getting the speedometer out... i know from experience: i've had my speedometer out three or four times.
"COOL PRIUS!" - Nobody Ever
Old 10-24-2003, 12:54 PM
bearone2's Avatar
they were seated. do you know if all these items in the instrument cluster are like xmas tree lites, one bad one kills the whole tree.
Old 10-26-2003, 11:19 PM
Not like x-mass lights in series but parallel.
Old 10-27-2003, 08:42 AM
bearone2's Avatar
thanks
Old 10-27-2003, 09:53 AM
