adrian jaye's Avatar
Question swaping a 924 engine for a 924s
Has anyone done this ? Any problems ?
Plus
1> How does one tell the difference between a 150 bhp ~ 9.7:1 compession ratio and the 160 bhp ~ 10.6:1 compression ratio by the engine serial number?
2> If the swap is not like for like does this impact the working of the ECU?
3> Can an auto designated engine directly replace a manual designated engine ~ ie bell housing differences?
cheers
A
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 10-22-2003, 01:00 AM
Wolf1's Avatar
I think this has been covered a few times, maybe do a search for the details. But the big things would be: swap cross-members, the 2.0 mounts to the body and the 2.5 mounts to the cross-member. All the injection plumbing and wiring would need to be swapped, the 2.0 is cis and the 2.5 is motronic. Something would have to be done in the clutch/driveshaft area to make up for the difference in shaft size. Etc..etc..etc..
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 10-22-2003, 06:29 AM
Alex Cook's Avatar
Adrian, I know nothing about the 'nuts & bolts' side of things, but I can answer your question about identfying the 150/160bhp versions (well my Morgan book can!)
1986 & 1987 150bhp - engine number starts 43G or 43H respectively
1988 160bhp - engine number starts 46J
Good luck!
Alex
'95 968 Sport, Iris Blue / black
'92 968, Guards Red / black (sold)
In the family: '90 944S2 & '86 911 3.2
Old 10-22-2003, 01:30 PM
Roger Hall's Avatar
Swaping a 924S mortor into a 924 is possible, but why do it. The amount of fabrication required would make it just as easy to install a much larger engine.
You would need
Motor mounts
Wiring harness
DME
Drive train
Fuel injection
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 10-22-2003, 05:28 PM
With the prices of 924S models at the moment, why would you even think about it?
By the way, the front frame rails of of the 924 and 924S are completely different.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-22-2003, 08:41 PM
It can be done but it is a lot of work. As noted above the cross members are different and mount differently. So you would need to do a lot of fabrication to mount the 924S cross member and thus the engine. I know the 924S/944 motors can be had for about $700 complete but you also need the complete drive train. The 924S/944 motor will not bolt to the 924 2.0 drive shaft (torque tube). The diameter of the 2.0L 924 is smaller.
So it would be a better option to just find a 924S.
Eric
www.geocities.com/eturbo924
82 924 restored, 83 944 parting out
In search of 1988 or newer nice 944.
Old 10-23-2003, 06:01 AM
cheers guys
it was another regions member who asked the question and as I'm a "fo fo" man, I was just asking
cheers All
A
NotJustPorsche
Old 10-23-2003, 06:48 AM
SoCal Driver's Avatar
Originally posted by adrian jaye
cheers guys
cheers All
A
An Adrian sandwich.
Hmm. Right hand drive. Must be difficult to find RHD 944's.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-23-2003, 08:50 AM
