ds475's Avatar
Send a message via AIM to ds475
blinker fuse keeps blowing
my blinker fuse blew 3 times yesterday, i'm about to just short it with some wire. why would it all of a sudden start eating fuses one day. i have never blown a fuse before.
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-22-2003, 05:54 PM
Scott R's Avatar
I had this happen to me as well, and in one large repair I cleaned all of the buld sockets with steel wool, and the negative battery grounds, and also the turn signal switch contacts.
Problem went away, but I don't know which phase of the repair arrested the problem.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-22-2003, 06:01 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
my problem went away after cleaning the grounds in the hatch area, I think it started after i go those a little bit wet vback there, when i was cleaning, give it a try, hopefully it fixes it, its a pain i know!
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 10-22-2003, 06:28 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
Speaking of grounds, alot of the problems that arise in these cars come from grounds. I would go ahead and clean all of them you can get to. There's a big one on the back of the engine, one next to and below the coolant tank on the frame, one by the headlight motor on the frame and a few other small random ones bolted in odd places. These are the main ones though.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 10-22-2003, 06:52 PM
ds475's Avatar
why would a bad ground cause a fuse to blow? it seems like it would be the other way around...
'82 928S
Old 10-22-2003, 10:12 PM
ds475's Avatar
i just thought of an idea, too. after steel wooling/sanding my ground, i'm going to get some silicone and try to seal the ground connection off from moisture. seems like a pretty good idea to me.
'82 928S
Old 10-22-2003, 10:18 PM
ds475's Avatar
Wilk, i don't get your comment with the quote...
'82 928S
Old 10-22-2003, 10:43 PM
ds475's Avatar
is the reason that when your grounds "go bad" you blow fuses, because there is more resistance, and therefore draws more current, and since the fuses/electronics are in series with the ground (no *****), it then blows your fuse(s)?
'82 928S
Old 10-23-2003, 08:09 AM
adrian jaye's Avatar
ds,
dont, dont dont, hear me now DONT
short the fuse, its dangerous and if anything happens you'll invalidate your insurance.
fix the problem, as, has been suggested
laters
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 10-23-2003, 08:27 AM
Send a message via Yahoo to Cebu
Use bearing grease or vaseline on ground connections and battery connections (after cleaning) and prevent corrosion and contact problems. On systems with dual contact bulbs, When the turn signal is activated, (it has wiper contacts inside the mechanism)if the ground is bad, the system seeks a ground and it is reverse current through the bulb contacts that causes the fuse to blow or the bulb to explode.
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 10-23-2003, 09:08 AM
ds475's Avatar
well... it's not like i have comprehensive anyway...
'82 928S
Old 10-23-2003, 05:15 PM
ds475's Avatar
Macfreak007, your idea worked! after i finally got around to cleaning the ground on the very back, and all of the corrosion off of the bulbs in my rear lights (and front blinkers) it stopped eating fuses! thanks!
P.S. in your post you stated that you cleaned all of the grounds in the hatch... i only know of one, and thats the one in the very back.
'82 928S
Old 11-17-2003, 10:43 AM
Let's go shooting.
Dark Skies's Avatar
You should use liquid rubber / Sikaflex or similar - don't use the type used for sealing plumbing / baths etc - it's usually got acetic acid in it and corrodes your wires / metal.
Better - put a dollop of coppaslip on it.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 11-17-2003, 11:10 AM
haha, awesome, yeah its amazing sometimes the things you never thought would help really do. Something as simple as grounds. Glad to hear it fixed the problem. That main ground is the only one i remember in the back i was wrong. But glad it worked
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 11-17-2003, 03:45 PM
