MrPants's Avatar
sinister radio
is it possible that my crappy aftermarket radio was wired up by some hillbilly and its draining the battery? i have kept the radio off for the past 2 weeks and the car has started no problem, then last night i had the radio on and BAM this morning it needs a jump. coincidnece?
84 944 Non Alcoholic
Old 10-25-2003, 11:43 AM
Let's go shooting.
Dark Skies's Avatar
Mmm. Your battery would have had to have been pretty low for the radio to have robbed all its juice - was the car running or just sitting there like a giant jukebox?
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 10-25-2003, 12:03 PM
vott does ziss do?
ronin's Avatar
you said you left the radio on. is the radio wired to be independent of the key switch? if it is, then yes the radio could have drained the battery overnight if it was left on, but I think you would have heard it
if that's the case, it has nothing to do with bad wiring
Old 10-25-2003, 12:30 PM
emwporsche's Avatar
It's highly possible
that he wired the power directly to the battery.
Have you not had this car long?
Also if you have any amps, check those.
My friend had the same prob, because someone installed the amp wrong.
Good Luck
Old 10-25-2003, 12:31 PM
MrPants's Avatar
no the radio wasnt on during the night, well im as sure as i can be after a baker's dozen of drinks. and it was only on with the car running.
ive had the car less than a year but the no start problem only appeared about 2-3 months ago. new starter, new battery, new ground strap, cleaned grounds, alternator checks out fine, im kind of stumped on this one. think ill take the POS sony out of there and introduce it to my foot.
Old 10-26-2003, 01:38 AM
SoCal Driver's Avatar
Electric antenna. May still be motoring after it hits it's stop.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-26-2003, 08:55 AM
MrPants's Avatar
hmm did any of these come with manual antennas? where would the antenna switch be?
Old 10-26-2003, 11:10 AM
vott does ziss do?
ronin's Avatar
lol, I can just see that, a handcrank antenna
Old 10-26-2003, 12:33 PM
There is a power wire and a switch wire that comes off of an electric antenna. The Power wire conncets to the fuse block. The switch wire is the one that goes to the radio.
Follow the wires out of the side of the car to their respective locations/attachments. Pull the wire to the fuse panel.
Old 10-26-2003, 12:50 PM
vott does ziss do?
ronin's Avatar
don't most power antennas have a timer circuit that stops after a predetermined amount of time
Old 10-26-2003, 01:29 PM
MrPants's Avatar
where do we adjust the power antenna from? ive just been physically pulling it in and out.
Old 10-26-2003, 02:58 PM
vott does ziss do?
ronin's Avatar
can't find it in the manual. SOCAL!!
Old 10-26-2003, 03:07 PM
Is it a power antenna or just a manual antenna? When the stock power antenna on mine died I couldn't move it anywhere.
Old 10-26-2003, 06:22 PM
vott does ziss do?
ronin's Avatar
once again, manual antenna?? wiith a handcrank?
Old 10-26-2003, 06:58 PM
MrPants's Avatar
i went out to look at it tonight. couldnt find the wires before it got dark, but there is a plastic cord attached to the bottom inside of the antenna. there is also a measuring tape sized metal box under the drivers side wheel well (next to the carcoal cansiter i beleive) that is a real pain to get at. is that the motor, or something else?
Old 10-26-2003, 07:01 PM
Need to look at the inside of the fender well up and behind the fuse/relay box. You may have to pull the carpet out a little. There would be some wires coming through as well as the larger antenna lead.
Other power drains: Gove box light. Fan temp switch or relay. Power amp for radio. Leaving the key in the ignition as this closes the radio circuit.
Old 10-26-2003, 07:05 PM
vott does ziss do?
ronin's Avatar
the plastic cord is what's used to extend/retract the antenna. yep, the reason why it's a biatch to get at is because you need to remove the wheel and emissions can to get at it. once you do that, you can loosen the ring on top and pull the whole assy out at the bottom
Old 10-26-2003, 07:10 PM
