-   -   engine vibration =$ (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/13322-engine-vibration.html)
90s2Rick 07-08-2001 06:09 PM
engine vibration =$
Unknown engine vibration on my s2 caused the oil pick-up tube in the oil pan to break,causing the lifters to go bad. Engine vibrates with clutch in or out.Relaced motor mounts, rollers,clutch system,& aligned belts with rollers.any idea's? PLEASE HELP this has cost me too much $$$$. THANKS
mideastmafia 07-08-2001 06:16 PM
does it vibrate all the time?
OR does it happen during:
IDLE
COLD START
HOT START
CERTAIN RPMS
CERTAIN GEARS.
elaborate
SHAUN
90s2Rick 07-08-2001 06:25 PM
Shaun, it vibrates at all times but is mostly noticed @ 3200rpm's it is felt on the engine itself, gear shifter & clutch pedal.
drew1 07-08-2001 07:14 PM
Rick,
Is it possible that balance shaft is out of time.
drew1?
mike944 07-08-2001 08:32 PM
I think Drew1 might have the right idea. If one, or both of the balance shafts are put on out of phase (VERY easy to do) it will vibrate worse than if it had no balance shafts at all.
Mike
Mrmerlin 07-08-2001 08:35 PM
[QUOTE]Originally posted by 90s2Rick:
hi Rick it sounds like one of the balance belts are out of time the only way to check is to remove the timing belt cover and see if the top balance pulley has a O showing thru one of the cutouts on the belt guide and the bottom pulley has the O showing thru one of the rectangular cutouts, the O means over..... early cars had 2 marks O and U marked on the pulley face they stopped putting the U on so if you dont see this then it is very possible that the bottom pulley will be out of time ... the other way to check this is to remove the balance belt and start the engine this will answer your question on the vibration.. if the pulleys are both indicating good then it is time to remove the balance covers and see if the weight has come loose , they are secured ith a set screw........Stan
TheStig 07-08-2001 09:36 PM
i have heard that balance shafts caused that too......just think like a 924....rough...no offense AMC http://www.pelicanparts.com/ultimate/smile.gif
http://eurospecporsche944.homestead.com/files/sig.jpg
Porsche. Es gibt keinen Ersatz.
Lawrence Coppari 07-09-2001 04:31 AM
I vote for balance shaft problem. It makes quite a vibration at double engine rpm if timing is off.
geoffbaltz 07-09-2001 07:16 PM
my 951 had the same vibration and we found that some dumb ass had the balance shaft 180 degrees off. Smooth as silk now.
Geoff Baltz
'86 944 Turbo
http://www.ninefiveone.com
