ds475's Avatar
Send a message via AIM to ds475
Under car filth!
I was looking at my tranny and those fins on the bottom side of my engine, and i was disgusted! that 1/8" layer of poo on the bottom side of my car is a disgrace and i want to get rid of it.
what should i use? power washer? gasoline?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-26-2003, 10:13 PM
AFJuvat's Avatar
engine degreaser, Wal-mart, $.79 per can - get 5 or 6 cans. Spray and scrub and spray some more, rinse as necessary
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-26-2003, 10:29 PM
Gunk Engine Brite. Spray on, work in with a brush, rinse with strong spray from a garden hose or pressuer washer. Repeat as necessary.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 10-27-2003, 05:55 AM
Be careful with a pressure washer down there. You don't want to get water where it don't belong.
1986 944 Turbo
Old 10-27-2003, 06:00 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
I used the stuff called "Purple Power" and a scrub brush then rinsed with water. Do Not Pressure wash as water will get into everywhere you don't want it.
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 10-27-2003, 06:06 AM
meister member
speedracing944's Avatar
On my tranny I scraped off the Poo with a popsicle stick then used a toothbrush and kerosene and scrubbed until there was a nice shinny tranny. The kerosene cuts through grease and grime easily. Wear gloves and goggles to protect yourself and don't get any on your paint.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 10-27-2003, 06:18 AM
ds475's Avatar
do those engine degreasers in the cans work as well as kerosene/gasoline? a gallon of gas is a lot cheaper than a gallon of that engine degreaser.
'82 928S
Old 10-27-2003, 01:44 PM
Using gas is a Bozo No-No. Too flamable.
Engine Brite and the like are safer and contain emulisifiers, so you can just spray on and hose off.
If you use a straight petroleum product like gas or kerosene as a cleaner, you have to use a detergent (soap) to remove the "cleaner".
Cliff Hipsher
'87 944 India Red
Old 10-27-2003, 04:32 PM
afx afx is offline
afx's Avatar
Send a message via ICQ to afx
I got a gallon of "purple power" from pep boys. I put it in a spray bottle and just sprayed away. I seems to work pretty well for me. I think that it was like 4 or 5 dollars, maybe less
85.5 Red 944
Http://members.rennlist.com/afx
Old 10-27-2003, 04:44 PM
TCMdocs944's Avatar
I have so much crap on the trans. I think it may be undercoating....underneath is nice clean metal
What's the best way to tell the difference?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 10-27-2003, 05:34 PM
ds475's Avatar
purple power... i think i'll go buy some tomorrow, i like the spray on/hose off idea...
'82 928S
Old 10-27-2003, 10:25 PM
Kirby2's Avatar
Be careful with the purple power, it is a strong alkalai. It tends to age rubber and dry things out a bit much. Between the power steering fliud making everything swell and the alkalai drying and shrinking things, pick up some suspension bushings, you'll need them.
The engine bright is much easier on all the other things you don't want ravaged.
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 10-28-2003, 08:35 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
ds475. exactly WHAT is your icon doing to the Honda box??
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 10-28-2003, 08:55 PM
ds475's Avatar
he is "pelvic thrusting" (maybe raping is better)honda, there may be penetration, but at that size, it is difficult to tell
'82 928S
Old 10-29-2003, 07:42 AM
vott does ziss do?
ronin's Avatar
one thing y'all forgot is to mention how you get under the car. do most of you use jackstands? ramps? fortunate enough to have access to a lift? I've been using jackstands so far, but soon I hope to have access to a lift to "do it right"
Old 10-29-2003, 07:47 PM
ds475's Avatar
i'd probably just stick it on some wooden blocks... i need/want some jackstands and a quality rolling jack...
'82 928S
Old 10-29-2003, 07:55 PM
vott does ziss do?
ronin's Avatar
yep, but it's soo much easier to do a good job when you can stand under the car
BTW: forgot to mention that my degreaser of choice is Castrol Superclean. works great, just remember to rinse like a mofo
Old 10-29-2003, 07:56 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
"You thrust your pelvis, uhhh! You thrust your pelvis, uhhh!"
-Duckman
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-29-2003, 10:01 PM
vott does ziss do?
ronin's Avatar
oh. now there's a blast from the past
Old 10-29-2003, 10:24 PM
Roger Hall's Avatar
I went to the local self serve car wash. I didnt want all the crud in the parking lot. Then I used The purple power and a pump sprayer to apply the degreaser. Then I used the sprayer to clean the underside. It worked great.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 10-30-2003, 08:02 PM
