Bay Area Patriot
TheStig's Avatar
noisy valve lifter or belt roller?
After trying to adjust an erradic idle i stumbled across a loud noise in the engine. It sounded like a worn out belt roller but its near the top of the cam box. Now I had the tensioners replaced in the car about 12,000 miles ago and they couldn't have gone bad already. Perhaps maybe I need a timing belt retension or is this something different...
Could this be a noisy valve, lifter, or a worn lobe on the camshaft????? need feedback please.... I'm goin through the Haynes manual and what they are saying.
Porsche. Es gibt keinen Ersatz.
Old 07-10-2001, 01:08 PM
Post
Eurospec
I had a bad noise like you describe, and it was the cam belt tensioner broken up, there were no balls left in the ball race part of the tensioner, I was miles from home but I got a new tensioner and changed it roadside.
Used up aboutb three lives that day!
Regards Barrie
Old 07-10-2001, 02:02 PM
88_944's Avatar
Cool
I had this same sound in the same place. I thought the sound was coming from the Disturbtor cap so I open it and put it back and the sound was gone. Try that.
PORSCHE There is no Substitute!
My 944 Site! http://www.skybusiness.com/dean/
Old 07-10-2001, 02:17 PM
Dave951M's Avatar
Post
You didn't mention what type of noise. If it's a "roaring" type of noise, that is usually a rotating part with a bad bearing or something rubbing. If it has a rythmic "beat" or tapping to it, suspect a reciprocating part like a lifter. Worn cam lobes are fairly rare. These hold true most of the time and will help find a logical starting place to look.
I thought I had a bad lifter, it turned out to be a broken exhaust stud on #4 near the firewall and as a result, the exhaust flange wasn't evenly torqued. This allowed a bit of exhaust blowby, mimicking a bad lifter. Before getting crazy disassembling, look closely for that kind of easy stuff. Also, spend the $10 for a mechanic's stethoscope. It will pay for itself in time saved very quickly.
Good luck
Dave951M
Old 07-10-2001, 05:33 PM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
make sure you have enough oil.
SHAUN
Old 07-10-2001, 05:55 PM
