Question Power steering
Currently my power steering pump is leaking BAD (87 944S). See any heartburn if I replace the pump with a 944 unit. The 944 unit does not have a pressure switch , but if I'm not mistaken Porsche put out a bulletin to disconnect the wires on the 944S pumps do to there was no short protection and the wires where burning up.
Old 10-30-2003, 09:24 AM
SoCal Driver's Avatar
Should work. No real difference in the racks.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-30-2003, 03:34 PM
vott does ziss do?
ronin's Avatar
show us your rack!!!
Old 10-30-2003, 03:58 PM
CSU944's Avatar
I just replaced mine recently; I got a rebuilt ZF (OEM) pump from Advance Auto for $145 plus a $50 core charge, (Pelican's $350 core charge was more than my credit card could handle at the time) and it had the port for the pressure switch which I just plugged. But if it's just leaking, I might consider getting a seal kit for it. I think I saw one online somewhere for about $20.
-Tom
Old 10-30-2003, 05:20 PM
I picked up a used one for $40 36K milkes on the car its being removed from, but its not an "S".
Old 10-31-2003, 06:39 AM
vott does ziss do?
ronin's Avatar
that sounds like a good price. as Hugh said, it should fit as there is no real difference in the rack. keep us informed. it'll make good reference for later
Old 10-31-2003, 09:29 AM
